Project "Silver TUF" by SS-PC modding
neSSa
i7 5820k + EKWB
MSI X99 Mpower
16gb HyperX Predator 2666Mhz
SLI - Asus GTX 770 dc2 + EKWB
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
A4Tech - mouse and keyboard
grickodj
Intel 4770k H55
MSI MPOWER Z87 SP
Corsair Vengeance
MSI 7950 water cooled
PHILIPS
Integrated
LC Power Executor
Corsair CS750M
X7 & Genius KB-G265
Windows 8.1 Mozila Firefox
Mouse pad x7
Meni takodje uz Alphacool rez. stigli bakarni cepovi. Inace radijator je babaroga. Svidja mi se takodje to sto za razliku od Phobya ima zastitni lim ispod rupa za srafove :thumb:
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Ne znam koji ti to Phobya rad imas (pretpostavljam prvu seriju), kod V2 verzija koje ja posedujem takodje imas tu istu zastitu!
grickodj
Intel 4770k H55
MSI MPOWER Z87 SP
Corsair Vengeance
PHILIPS
Integrated
LC Power Executor
Corsair CS750M
X7 & Genius KB-G265
Mouse pad x7
Nemam ni jedan, ali sam vidjao.
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
radiator fits perfectly...
sinda
MSI B550 Tomahawk Max
AOC 24" G2U 144hz
integrale
INWIN 303 Case
Corsair HX750i
Sunce ti zarko,tek sad vidim koliko je ogromno ovo kuciste!!!
Sent from my ZTE Blade Q Maxi using Tapatalk
_GiBo_
_GiBo_
GIGABYTE AX370-GAMING 5
DELL P2417H
Integrisana/2.0 Genius Wooden
Thermaltake SPS 730M - 730W
SBB Superset - 110/6 Mb/s
/Nexus 6P/8.1 Оrео/
Ма пусти кућиште, ја тек сад контам колики је радијатор :)
Sent from my Galaxy Nexus using Tapatalk
grickodj
Intel 4770k H55
MSI MPOWER Z87 SP
Corsair Vengeance
PHILIPS
Integrated
LC Power Executor
Corsair CS750M
X7 & Genius KB-G265
Mouse pad x7
Ja se nadam da ventilatori nece ostati u push push konfiguraciji :d
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
kuciste jeste fulltower ali ne moze da primi 560rad hehe, ovaj monsta je stvarno impozantan jos u pp i ode trecina prostora unutar ovog velikog kucista, ventilatori su cisto radi probe namesteni a ne da rade, jos uvek nisam zamislio konstalaciju ventova tj. koji ce napred a koji unutra ali otom potom. Sledi odradjivanje osvetljenja od belog plexija na dnu i razno razni coveri po unutrasnjosti...
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Asus GTX 770 dc2oc + ekwb
Proka
Prox
I7 4790k
Asus Maximus VII Impact
ASUS 980TI
ASUS PG348Q
Custom build
Asus CLAW, Asus Tactic PRo
SBB Fiber 40/5
Лепо лепо, беше уз овај Asus се подразумева backplate или сам ја нешто погрешио?
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Karta vec ima na sebi originalni Asus od brusenog aluminijuma :)
Proka
Prox
I7 4790k
ASUS 980TI
ASUS PG348Q
Custom build
SBB Fiber 40/5
Да да, тако сам и мисло а мрзело ме да гуглам.
Качи слике када спакујеш блок. :)
perestrojka
Drlog #1
i5 4690k // 5GHz @ 1.425V
Asus Sabertooth Z97 Mark 1
Corsair XMS 3 / 3 x 2GB 1333MHz
Gainward GTX 980
Acer V223HQV
Intel 520 120gb / Mushkin DX 60gb / WD RED 1TB
on-board
Powertosh i5 custom case
Seasonic Fanless 520W
Logitech G602 / Razer Lycosa
2Mbit cable @ Mikrotik Routerboard
Win 8.1 / OSX 10.10.3
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Odmah i sada! :butcher:
Salim se samo polako :kokice:
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Two Asus GTX 770 dc2 with EKWB fc block and EKWB bridge, moonson fitings is for test only :)
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Stigla nadogradnja za DDC pumpu od EKWB :)
grickodj
Intel 4770k H55
MSI MPOWER Z87 SP
Corsair Vengeance
PHILIPS
Integrated
LC Power Executor
Corsair CS750M
X7 & Genius KB-G265
Mouse pad x7
lepo, nego sta slikas tu kutiju. Slikaj sta je u kutiji.
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Od radosti ne pade mi na pamet, evo kako izgleda kad se namontira :d
Samo da naglasim da EKWB Heatsink apsolutno pasuje sa Phobya topom, srafovi za spajanje su korisceni oni iz EK paketa!
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Imedju pumpe i reservoara koristicu Swiftech brzu spojku radi lakseg postavljanja i kasnijeg odrzavanja sistema ;)
grickodj
Intel 4770k H55
MSI MPOWER Z87 SP
Corsair Vengeance
PHILIPS
Integrated
LC Power Executor
Corsair CS750M
X7 & Genius KB-G265
Mouse pad x7
Moram priznati da mi se jako svidja sto si prikacio rez ba prednju stranu pumpe umesto na gornju. Ako se ne varam, nisam nigde vidjao da je neko tako kacio :)
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Da, simptomaticno je da svi upravo stavljaju ovu pumpu na dno kuicista i zato tako i pada da res bude na TOPu pumpe, kod mene ovog puta pumpa ide na MB tray zajedno sa rezervoarom i upravo ce stajati ovako, pritom i da pokazemo sav sjaj nikla "silver TUF" projekta :)
DR4C0Ni4N
i9-10900F | CWB-C1
MSI MEG Z490 Godlike
64GB Corsair & Patriot
EVGA RTX 3080 FTW3
Dell U2722DE
1TB Samsung 970 EVO Plus
Cooler Master V850
Moze da stoji i tako vertikalno, tj. zasrafljena na tray umesto dno kucista?
