Project --Monochromatic 2013-- (Worklog)
deluxe
Acer Aspire V3-771G
AUO HD+ 17.3" 1600x900 LED
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Telemark 2048 KB / 256 KB
Bluetooth 4.0
pa matori, nisi mi se pohvalio :d samo cepaj! ;)
sinda
MSI B550 Tomahawk Max
AOC 24" G2U 144hz
integrale
INWIN 303 Case
Corsair HX750i
I kao sto rekoh,nastavak radova ;) seckanje prozorceta i jos ponesto ;)
sinda
AOC 24" G2U 144hz
integrale
INWIN 303 Case
Corsair HX750i
...i naravno,odlican rezultat ;)
:obrva:
:sekira::wave:
ZiZ0
Intel I5 4690K
MSi Z97 Gaming 5
Asus GTX 980 Strix
Dell U2312HM
Kingston HyperX Cloud 2
Fractal Design XL R2
Cooler Master GX 750W 80+
Uhhh, kakve fotkice :D Svaka cast, samo napred ! :) Imas malo lima viska ? :D
neSSa
i7 5820k + EKWB
MSI X99 Mpower
16gb HyperX Predator 2666Mhz
SLI - Asus GTX 770 dc2 + EKWB
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
A4Tech - mouse and keyboard
Lepo ti ide, zasto si se za prorez na ventu odlucio bas za cetvrtastu varijantu?
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
to gene! :appl: prozor na stranici si majstorski izrezao, svaka cast! :thumb:
sinda
AOC 24" G2U 144hz
integrale
INWIN 303 Case
Corsair HX750i
Pa,zato sto ce mi tu ici intake vent,i umesto one CM turbine,ici ce neki "redovnog" oblika,sa dosta vecim brojem obrtaja,koje cu naravno moci da kontrolisem.....inace,ipak sam odlucio da ce exterijer kucista biti bele boje;)
Super je ispalo sinda! :appl:
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
full belo eksterijer ili samo neki delovi? valjda nisi smislio isto sti i ja :d u suprotnom moram da menjam, izgledalo bi kao delimicno kopiranje a to ne zelim.:)
grickodj
Intel 4770k H55
MSI MPOWER Z87 SP
Corsair Vengeance
MSI 7950 water cooled
PHILIPS
Integrated
LC Power Executor
Corsair CS750M
X7 & Genius KB-G265
Windows 8.1 Mozila Firefox
Mouse pad x7
Bela je ne zamenjiva za enterijer.
sinda
AOC 24" G2U 144hz
integrale
INWIN 303 Case
Corsair HX750i
E drugari.....samo da se oglasim da sam ziv i da radim nesto,cisto da ne pomislite da sam se (nedaj Boze) ulenjio ;) Sada cu u kratkim crtama pokusati da vam iznesem i obrazlozim neke nove ideje koje su se "rodile" u vezi ovog moda :) prva bitna stavka,tice se samog exterijera,koji ce biti farban u belo,ipak sam tako odlucio,pa nek ide zivot!Druga stvar,tice se onih custom panela,ipak cu ostati na originalnim mrezicama,dok ce recimo samo prednju mrezicu krasiti jednostavan custom-logo,koji je vec smisljen ;) Druga stvar,tice se vodenog hladjenja,tj ipak necu koristiti H70 Core,nego cu umesto njega u celu pricu ubaciti CM Eisberg 240L,koji mi je dao jos dosta nekih ideja,i sa kojim ce sama unutrasnjost izgledati dosta drugacije od prvobitnog plana.....radicu i neki light-panel u samoj unutrasnjosti,ali otom potom,videcete vec,i nadam se da ce vam se nove ideje dopasti! ;) Danas sam odneo sve sto treba da se ofarba na peskiranje,u cetvrtak farbanje,a za vikedn foto-session kucista,da vidimo kako je sve ispalo ;) To bi bilo sto se samih promena tice,a danas sam recimo dosao na sledecu ideju,a vi prokomentarisite dali vam se dopada ili ne.....radi se o jednom delu kucista koje bi se trebalo ofarbati u belo,(deo ispod stranica) medjutim,dok sam smirglao danas taj deo,pade mi nesto napamet,mozda bih i mogao da ga ostavim u ovakvom stanju,posto se jako lepo slaze uz nogice kucista,a kontam da bi i samom kucistu dalo neki luksuzni-retro-industrijal smek?!Ajmo,komentari! :)
....a sa belo stranicom bi to recimo izgledalo ovako:
....koristio sam belo parce papira da "simuliram" izgled sa belom stranicom ;)
Eto,to je ideja,slobodno komentarisite,dali da ostavim tako ili da tak deo ofarbam u belo......mada,realno sto se mene tice,ja bih ga ostavio u ovoj "osmirglanoj varijanti (naravno,jos malo dodatno treba ispolirati sitnijom smirglom)
bora bora
Toshiba L500-12P
Intel i5 2400 + Hyper212Evo
Gigabyte H67
Kingston Fury 2x4gb 1866mhz
ATI Radeon R9 270
Dell P2414H
WD 500gb + Samsung 1tb
Sony XB400
Built, not Bought!
LC Power
LiteOn
Telekom ADSL
Win7
eto drago mi je da sam odbio te mrezice kad si mi ih nudio, jer sam znao da ce ti kad tad zatrebati :D mada bi svakako kompletniji mod bio sa nekim custom panelima, ali to mozes i naknadno da odradis... ;)
sto se tice tog ismirglanog dela, ja da imam to core 1000 kuciste, izlepio bih ga sa "brushed aluminium" folijom koja ima na kupujem prodajem, unutrasnjost ostaje crna, mrezice ostaju crne, a ispalo bi jeftinije nego peskarenje ;)
http://www.kupujemprodajem.com/Bruseni-aluminijum-Auto-Folija-4502838-oglas.htm?filter_id=22132306
sinda
AOC 24" G2U 144hz
integrale
INWIN 303 Case
Corsair HX750i
Neznam,nisam nesto ljubitelj folija,tako da bih ga radije ovako ostavio.....
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
gene, ja tu ne bih nista dirao :D
malo sam iznenadjen da neces da radis custom panele, nije ih teko napraviti, samo bih ja da sam na tvom mestu koristio i mrezicu sa custom filterom, vec sam razmisljao o tome i znam kako bih to da mogao da ukomponujem zajedno ali nemam dizajn samog panela ... kad bih bar znao neki program za crtanje (ne google sketch up).
inace :appl:
bora bora
Toshiba L500-12P
Gigabyte H67
ATI Radeon R9 270
Dell P2414H
Sony XB400
Built, not Bought!
LC Power
LiteOn
Telekom ADSL
Win7
custom paneli mogu za cas da se odrade i papnu umesto mrezica sto verujem da ce sinda i odraditi pre ili kasnije...ostatak je bitan :P
sinda
AOC 24" G2U 144hz
integrale
INWIN 303 Case
Corsair HX750i
Ma neradi se uopste o tome dali ih je tesko odraditi ili ne,sve je spremno,bukvalno nabacim na flesh i odnesem da mi se odrade,ali eto,sad mi sinula neka druga ideja,a i mrezica sa prednje strane mi je u ovom momentu dosta prakticnija,jer ce kroz nju 240 radijator izbacivati topao vazduh...;)
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
kako izbacuje? hmm, ti si sve okrenuo naglavacke :d
bravo majstore i pozdravljam ideju koju si smislio :)
ostavi to dole da se uklopi sa nogicama :)
vise bi veleo da budu crno ofarbane stranice spolja :)
cekam slikanje da vidim sve sklopljeno :)
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Ako ostavljas taj metalni izgleda dole, onda obavezno po mom skromnom misljenju ostavi i stranice crne, barem meni bolje izgleda nego bela i alu varijanta.
sinda
AOC 24" G2U 144hz
integrale
INWIN 303 Case
Corsair HX750i
Nema sanse da cu ostaviti crne stranice,smucila mi se crna boja vise!:) videcemo sad za koji dan na cega ce sve.da lici,u najgorem slucaju mogu prefarbati taj deo ako se lepo ne uklopi,ali opet kazem,videcemo za koji dan kako ce sve cucnuti.....
Podrzavam promene, crna je stvarno dozlagrdila, izgledalo bi elegantnije sa crnom, ali treba menjati navike ;)
Takodje nisam pristalica folija, osim negde gde mogu da skrate muke.
Sinda za sad sve odlicno kao sto si nas i navikao :)
neSSa
i7 5820k + EKWB
MSI X99 Mpower
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
Mozda da iznutra ostavis metal look, a spolja prosaras, probaj i sve ce ti se samo kazati...
sinda
AOC 24" G2U 144hz
integrale
INWIN 303 Case
Corsair HX750i
E drugari....samo da javim da je "operacija" 90% uspela :) onih 10% se odnosi na ponovno farbanje stranica,posto su na par mesta ostale neke gromuljice,jbg,nismo dobro procedili farbu pre sipanja u pistolj.....sve u svemu,danas cemo malo samo preci vodenom smirglom,lepo procediti farbu,pa ponoviti postupak,sve u svemu,bice extra,ja sam svakako prezadovoljan!Par fotkica da se vidi bar nesto od rada,a ostatak sutra,kad stranice pristignu ;)
Sve u svemu,pravo osvezenje,posle svog tog crnila ovih godina :d
fr0wn3r
Upečatljivo! Nisam ni mislio da će loše izgledati - promena plana, ali definitivno je pun pogodak!
Svaka čast!
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
uuuu bas je dobro ispalo, vrh gene! :appl:
