Asus Z690G-Gaming Wifi
AsRock RX6900XT OC Formula
BenQ EX2780Q/Hisense 65u8gq
LIAN LI PC-O11D Mini TG black
Optika 400/80
Sourceooling expert and power supply maker Xigmatek today extends its range of interests and is now officially producing computer cases too. First Xigmatek case to enter retail production is the 53 x 502 x 563 mm measuring Midgard mid tower enclosure. The steel case is all coated in black, both from the inside and the outside, and targets gamers on the low budget. Up to five 5.25-inch optical devices can be installed in the case, as well as up to five 3.5-inch hard drives, the hard drive cage is also rotated 90-degrees to save space. No instruments are needed when installing components inside the case. For maximum cooling, two 120 mm Xigmatek white LED fans come with the case, one in the front and one at the back, but there are holes for up to five more 120 mm or 140 mm fans (two on the side panel, one at the bottom of the case, and two on top). Other neat features include water cooling holes, cable management system, and a big gap in the motherboard try, for easy processor cooling manipulation. The Xigmatek Midgard is supposed to ship on June 12, 2009 for the price equivalent of 60 Euros.
