Ventilator za Thermaltake Toughpower XT 775W
janca
Asus N50V
Intel i7-7700K + CM 212 EVO
MSI Z270 Tomahawk
CORSAIR 16GB Vengeance LPX DDR4 3000MHz CL15 KIT
Gigabyte GTX 1050ti OC 4GB GDDR5 Windforce
Benq XL2411Z
Samsung 850 EVO 250GB + Hitachi 320GB
Asus Essense STX, Mitsubishi M-U5100 AMP, Sony SS2070, Sennheiser HD555
Cooler Master Enforcer
Thermaltake XT 775W
Zowie ESC1-A, Zowie GS-R, SS 6gv2
SBB 60/4
Win10, Chrome
Originalni je prilicno bucan, koji bi ventilator mogao da zameni originalni. Mislim da ide 14ica
Istekla garancije prosle godine, tako da bih ga rado zamenio.
Menjanje ventilatora na samom napajanju je malo komplikovanije. Moras da mu prepravis konektor. Ja bih ti preporucio ovako nesto
NOCTUA NF-A14-PWM Hlađenje i kuleri
Noctua ventilatori su poznati kao tihi a sdruge strane izuzetno kvalitetni koji traju godinama bez ikakve greske u radu.
pjescic
i7 6700-K & BE QUIET Dark Rock Pro 3
ASROCK B150 Combo 6 slots DDR3 + DDR4
ddr4 16 gb anarhy
ASUS ROG Strix GTX 1060 6GB & Corsair SP120 Quiet Edition
LG 55UJ670V 4K UHD Smart 55" LED TV
samsung 840 ssd x1 , wd 2 tb x 3
Asus Xonar DSX
Fractal Design Define R4 Black Pearl
FSP Aurum PRO 850W GOLD
lg dvd rw
M705 Wireless & Logitech K520
drug nisam siguran ali mislim da je promjer tog venta kod tebe 13,5 jer to je sad standardna velicina venta na napajanjima
Model TP-775AH3CC
Type Intel ATX 12V 2.3 & EPS 12V 2.91
Max. Output Capacity 775W
Peak Output Capacity 875W
Color Black
Dimension ( W / H / D ) 150mm(W) x 86mm(H) x 160mm(L)
PFC (Power Factor Correction) Active PFC
Power Good Signal 100-500 msec
Hold Up Time 15msec (minimum) at 80% of full load at 230Vac input.
Input current 115Vac / 10A max. 230Vac / 5A max.
Input Frequency Range 47 Hz ~ 63 Hz
Input Voltage 100 VAC- 240 VAC
Operation Temperature 0℃ to +50℃
Operating Humidity 20% to 90%,non-condensing
Storage Temperature -20 ℃ to +70 ℃
Storage Humidity 5% to 95%, non-condensing
Cooling System 140mm dual ball bearing Fan:1900 RPM ± 10%
Efficiency 82% ~85% at full load (typical) and 115Vac input. Up to 89% at 230V Input.
MTBF 120,000 hrs minimum
Safety Approval UL/CUL, FCC, TUV, CE, BSMI, GOST
P/N TPX-775M
janca
Asus N50V
MSI Z270 Tomahawk
Benq XL2411Z
Thermaltake XT 775W
SBB 60/4
Win10, Chrome
Na specifikacijama sam video da je 140mm.
Razmisljao sam izmedju Noctue zbog proverenosti ili mozda BeQuiet zbog tisine, mada mislim da je i Noctua necujna.
Ackiss
Laptop HP ProBook 4530s
ROG Strix X570 Gaming E
GTX 1070Ti
Samsung Odyssey G7 32
Phanteks Evolv X/Noctua IPPC
VDSL 50mbps
Win 10 64bit, Chrome
Mislim da je Pjescic u pravu, ja imam Chieftec APS 1000c i na svim sajtovima pise da ima 140mm fan, medjutim pre par godina sam ga menjao i znam da je fan i njemu 135mm, ja sam to resio tako sto sam ubacio Noctua fan od 140mm i one njihove silikonske "srafove" koji su se malo rastegli da nebi morao da prosirujem rupe na napajanju..
janca
Asus N50V
MSI Z270 Tomahawk
Benq XL2411Z
Thermaltake XT 775W
SBB 60/4
Win10, Chrome
Jel se dobijaju ti srafovi (gumice) uz kuler?
I jel moze neki video ili objasnjenje kako treba da prepravim konektor?
Ackiss
GTX 1070Ti
VDSL 50mbps
Pitaj prodavce, znam da se uz neke noctua ventove dobijaju te gumice a uz neke ne.. Imas 3pinske i 4pinske varijante ventilatora, a na napajanju imas 2 pinski konektor tako da znas da nece biti samo plug and play, vec ces morati da budzis malo, ali to nije nista strasno samo imaj to na umu..
Na napajanju imas 2 pina, plus +12v(Crvena zica) i masu ili GND(Crna zica)
na slici ti ja sema 4pin konektora, bitno je da 12+ i GND dovedes do svojim mesta na 2pinskom konektoru od napajanja
Ako ti nije jasno, obajsnicu ti detaljnije, samo reci, jer ne znam koliko si strucan oko toga pa da ne gubim vreme ako si shvatio..
janca
Asus N50V
MSI Z270 Tomahawk
Benq XL2411Z
Thermaltake XT 775W
SBB 60/4
Win10, Chrome
Hvala na objasnjenju.
Kad spajam crvenu i crnu (vent - konektor napajanje) klasicno da zalemim i izolirkom da obavijem?
Narucujem najv ovu noctu-u iz drugog posta, provericu samo idu li gumice uz isti.
Kad bude stigao vent javljam se ako budem imao problema.
pjescic
ddr4 16 gb anarhy
Asus Xonar DSX
lg dvd rw
ma proizvodjaci namjerno stavljaju taj cudni promjer 13,5 da je sto teze obicnom korisniku da nadje i zamjeni vent u danasnje vrijeme vise nista nije cudno .
Thermaltake - Toughpower XT 775W
Minimum voltaža manja od 4V.
Originalni fan koji se pokreće sa 1.5V i Noctua sa 4.5V tako neće se ta Noctua pokrenuti, što nije dobro.
Ackiss
GTX 1070Ti
VDSL 50mbps
Najbolje sa termo buzirom da izolujes, ako ne onda izolirkom, nikako nemoj da ostavljas neizolovano jer u napajanju je sve skuceno i moze nastati havarija ako 12+ neizolovana zica dodirne neki kondenzator ili bilo sta drugo..
Ackiss
GTX 1070Ti
VDSL 50mbps
Pogledajte prilog 26735
Ovo jeste problem, samo pitanje je da li njegovo napajanje kontrolise vent naspram opterecenja ili temperature, a to naravno nikako ne mozemo saznati..
Samo da je 0.5v veca minimalna voltaza na napajanju bilo bi idealno..
Ja se ne secam koliko moj chieftec daje kao minimalnu voltazu, ali znam da sam stavljao jedan keramicki otpornik da bi dodatno smanjio minimalne obrtaje. Samo ja sam ubacio Ippc 140mm Noctua tako da je verovatno i startup voltaza drugacija na mom ventilatoru..
Ackiss
GTX 1070Ti
VDSL 50mbps
janca
Asus N50V
MSI Z270 Tomahawk
Benq XL2411Z
Thermaltake XT 775W
SBB 60/4
Win10, Chrome
Probacu da nadjem u Le buzir da uzmem ako ne onda cu izolirkom...
Imam osecaj kao da nema regulator za obrtaje i da uvek vrti max.
Da li bi mogao ikako da proverim "Samo da je 0.5v veca minimalna voltaza na napajanju bilo bi idealno" ?
Ackiss
GTX 1070Ti
VDSL 50mbps
Moze da se proveri tacan napon sa unimerom, ako si malo strucan i imas unimer mozes lako to odraditi, a i ako nisi strucan, u bilo kom servisu mogu to da ti izmere, dovoljno je samo da otvoris napajanje, odneses im otvoreno i pokazes im gde je konektor od ventilatora pa neka izmere napon, u roku od 5 minuta to mogu da odrade i onda ces za sigurno znati sta i kako dalje..
Umesto tog venta od 3000 dinara, bolje da uložiš pare u novo napajanje, samo napajanje ti ne vredi toliko naročito ako je otišao kontroler venta.
janca
Asus N50V
MSI Z270 Tomahawk
Benq XL2411Z
Thermaltake XT 775W
SBB 60/4
Win10, Chrome
Sad razmisljam i o toj soluciji... da se uopste ne maltretiram da uzmem novo :/.
Nisam siguran da je otiso nego je bucno od prvog dana do sada...
janca
Asus N50V
MSI Z270 Tomahawk
Benq XL2411Z
Thermaltake XT 775W
SBB 60/4
Win10, Chrome
Da li bi taj BeQuiet mogo da zameni originalni?
