Lukija
PCAXE Eminent Guru
After months of end user complaints, SandForce has finally duplicated, verified and provided a fix for the infamous BSOD/disconnect issue that affected SF-2200 based SSDs. The root cause is a bug in the firmware, although specifics are pretty slim. The typically sparse release notes just state a rare condition resulting in a blue screen error has now been addressed. OCZ has been testing the fix in-house for the past three weeks and now believes it is fit for public release. SandForce is simultaneously releasing the firmware to its partners, so if you have non-OCZ drives you should contact your drive manufacturer for an availability update.
http://www.anandtech.com/show/4973/sandforce-identifies-firmware-bug-causing-bsod-issue-fix-available-today
