Rx 580 i monitor problem
Zdravko
i5-3470 & Cooler Master Hyper tx3 evo
asus p8h61-m lx3
8 GB DDR3
MSI GTX 1070 Gaming X 8gb
Asus VP247HAE
1TB Seagate Baracuda & Gigabyte SSD 240GB
Odma na početko ima kao opcija ... ili je možda "new install"
znaci predlazes mi da puted DDU izbrisem drajvere i onda kad pokusam da instaliram drajvere da idem na fresh install ili new install kako vec pise?
Ace Rimmer
ASRock B550 Extreme4
Kingston FURY Beast 128GB
HP 23"
Samsung 980 PRO 1TB
onboard
Corsair 4000D Airflow
Riotoro ENIGMA G2 850W
DSL
Linux / Windows
Uninstall, pa DDU pa "new/fresh" install.
Cusu 2 x 16 GB DDR4 3600 MHz
SiliconPower A55 500 GB sata ssd + Seagate 5 TB sata hdd + Cusu 512 GB 3500q nvme
Ddu preporučuju da se pokrene iz Safe Mode.
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Opet nista, sve i da lje isto, meni kad stavim na show only on 1 (a to mi je tv ) stoji cekirano make this my main display, kad pokusam da stavim show only on 2 (sto mi je monitor) kako bi cekirao da mi monitor bude main display meni je crno na monitoru i na tv-u i onda ne mogu to nikako da prebacim...
Je li to ganc noca grafička karta? Kupljena u prodavnici? Neotpakovana? Razjasni malo...
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Nova novcijata juce kupljena u prodavnici...bukvalno neotpakovana sa saphire onom nalepnicom koja se sece da bi se otvorila kutija...
Ace Rimmer
HP 23"
Samsung 980 PRO 1TB
onboard
DSL
Linux / Windows
Ovo je sa MSI foruma vezano za HDMI portove, tako da nemoj pokušavati 2 ekrana:
"I think the 2 HDMI ports are meant for running a VR headset only and other people seem to have the same issue with trying to use 2 HDMI ports for monitors!
what seems to be the fix for the problem is getting a passive DP (Display Port) to HDMI Cable to get a signal off the display port instead!
its probably the 2 HDMI ports are expecting to see a Single device not 2 separate ones so its unable to handshake the 2nd monitor!"
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Ovo je sa MSI foruma vezano za HDMI portove:
To sam i ja naso isto, sutra kupujem kabl koji na jednoj strani ima DP a na drugoj HDMI i nadam se da ce to da mi resi problem...
Takodje pokusao sam da ubacim DVI adapter koji je na jednoj strani DVI muski (ide u graficku) a ima izlaz HDMI tj da se bocne HDMI kabl i ista je situacija...
Da li je moguce da je drugacije sa DP u odnosu na DVI?
Ne bi trebalo da je ikako drugačije. To mora da radi na jednom hdmi portu. Ovo što je postavio @Ace Rimmer ima smisla sa dva hdmi uređaja, ali sa jednim.... Ovo je čista situacija.
Što se tiče dp2hdmi kabla, ako ne budeš našao (nisam siguran koliko su dostupni i jeftini) možeš da probaš dp2hdmi adapter. Lično volim one gde su konektori na kabliću i po mogućstvu da može da prenosi i zvučni signal.
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Pa meni je najvise cudno sto kad povezem monitor preko HDMI nece da prikaze sliku a na tv hoce...
naso sam kabl dp to hdmi i to 1.8 metra za 700-800 dinara tako da to sutra uzimam i nadam se da ce da radi, a kako to mislis konektori na kablicu, mislis adapter koji sa jedne strane ima dp pa kratak kabl od tipa 10-ak cm pa onda hdmi konektor?
Ace Rimmer
HP 23"
Samsung 980 PRO 1TB
onboard
DSL
Linux / Windows
Da, to je adapter na koji kasnije priključiš standardni hdmi kabl. Ali ako ti je taj kabl o.k. - kupi ga.
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Valjda ... ako ti treba adapter. Ja uzeo DeLock-ov, ovaj:
Adapter DELOCK, DisplayPort (M) na DVI-I 24+5 (Ž), bijeli
Probao na RX570 i HD7790, radi u oba slučaja.
Probaj još jednom s "čistim" driverom, ali prvo probaj kombinaciju s monitorom .... koja ti sada ne radi.
Naso sam i ja DELOCK ali samo display port na VGA jer moj monitor ima HDMI i VGA port a nema DVI
Kako si mislio da probam s cistim drajverima ali prvo s monitorom?
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Pa probacu i videcemo sta ce da bude, brate mnogo ti hvala jer ovde vec dva dana pokusavas da mi pomognes a imam izgleda cudan i veliki problem
Pa, ja sam zato na ovom forumu. A vidiš da isto rade i @Djolekg i @Ace Rimmer ?! Poslednja šansa ti je reinstalacija Windows. Jesi li proveravao da li postoji neka nekompatibilnost Saphire - Asus..
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Naravno pomazu momci hvala i njima dosta, nisam proveravao onl kompatibilnosti
Ace Rimmer
HP 23"
Samsung 980 PRO 1TB
onboard
DSL
Linux / Windows
Može biti da je zapamtio settinge od TV-a pa da to forsira. Nabadam sad.
Što se tiče kablova, kartica podržava HDMI 2.0 i DP 1.4 standard pa se vodi time ako nabavljaš.
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Prvi put kad sam ubacio kartu u komp povezao sam prvo monitor tv nisam ni ubavivao, nisam imao sliku na monitoru a cim sam prikljucio tv dobio sam sliku na tv tako da ne verujem da je moglo prvo da povuce od tv-a jer on je kasnije prikljucen a monitornje prvi
Ovaj kabl DP to HDMI ne znam koji je ali ne znam ni koji se tu standard vec gleda jer su dva razlicita konektora
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Jos nesto sto mi je cudno, uzmem drugi tv i prikljucim ga na HDMI i onda mi dva tv-a prikljucena na posebnim HDMI kablovima i sve funkcionise normalno a mogu da izaberem koji cu da koristim od ta dva a kad vratim na monitor on ne radi, a monitor sam probao na drugi pc preko HDMI i radi a cak sam ga i vezivao na lap top i sve radi
Si probao da vrneš staru grafiku u pc i povežeš na monitor isto hdmi..
To si već bio napisao. Kupi sutra nešto da priključiš u dp, ne vredi više razbijati glavu ovim. :)
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Zdravko
asus p8h61-m lx3
8 GB DDR3
Asus VP247HAE
Ja bi bacio tu grafiku u tri lepe ....Ostaje ti da stavis tu rx u drugu konfu i probaš na isti monitor ili da vrneš gpu..
