Problem / potrebna pomoc
direktor123
Ako zna neko u cemu je problem i sta treba uraditi , ovo mi se vec 2 puta desilo kada sam igrao igru . A ponekad izbaci i drugi problem , oba problema izbacuje samo kad igram istu igru (igra je instalirana sa originalnog sajta tako da do igre stoposto nije ),inace imam windows 7 , 8gb ram , bez ssd-a. Racunar je nov ima godinu dana .
Cloudhate
AMD Ryzen 5 5600
B550 Aorus elite ax 2
Kingston Hyperx Fury rgb 4x8gb @ 3200mhz
XFX SWFT 319 RX 6800
Gigabyte G27Q 2560 x 1440 (QHD) @ 144hz
Samsung 980 PRO 500gb + ADATA xpg sx6000 500gb + Bunch of HDDS
Steinberg UR22 + Fluid Audio F4 + Cooler Master MH-752
NZXT H510 Elite
NZXT E850
Razer Naga Chroma + Razer Blackwidow V3
SBB Eon Premium 500/50
Win 11 x64 , Google Chrome
Cooling: NZXT Kraken x62 Chair: Sharkoon Skiller SGS 2
Prema informaciji iz samog bsod, izgleda da te muci avast antivirus. Preporučujem ti da ga obrises i da koristiš samo malwarebytes po potrebi, ako znaš šta skidas i koje sajtove posećujes.
uco73
Dell Precision Workstation T7600
Intel Xeon E5-2690 C2 8C 16T 20MB l3 cache 8GT/s QPI
Dell 082WXT dual 2011 socket
32GB QUAD Channel DDR3 Hynix ECC Registered 1600MHz CL12
Nvidia GTX 1080 Ti Asus Turbo 2xLonger Lifespan with Dual Ball Bearing Fan
Dell S2419HGF 24" 1920x1080 G-SYNC 144Hz 1ms
Lite-On IT LCS-256M6S 2,5 7mm, WDC WD10EZEX-00WN4A0 1TB, Toshiba DT01ACA100 1TB, Seagate ST2000VX000
Logitech Z323, Philips SHP2500
Dell Precision T7600
Dell D1300EF-00 1300W 180A Delta Electronic
PLDS DVD+-RW DS-8A9SH
Zelotes C12 Custom Gaming Mouse , Kingston HyperX Alloy Elite RGB
5Mb/s DL 0,7Mb/ UL tiha jeza, LOPOVI!!!
Windows 10 Pro x64, Chrome
Honor 50 Lite + Hisense Infinity H40 Rock
