pitanje u vezi ove konfiguracije
goran1988
Pozdrav,svima hteo bih da vas pitam u vezi ove konfiguracije sta vi mislite posto se verovatno vise razumete nego ja samim tim treba mi vas savet da li je ovo pravi gejmerski komp ovo su specifikacije
Graphics processor: NVIDIA RTX 2080Ti 11GB GDDR6
HDD Hard Drive Capacity: 2TB Manufacturer
Warranty: 2 years
Special features: Virtual Reality Ready Processor
Type: Intel Core i9 9900K
Modified article: Yes Brand: NSA Computer
Modification description: The system is delivered fully operational with installed and activated Windows 10 Pro 64 bit including current drivers and Windows updates.
Memory: 16GB
Hard Drive Type: SSD
SSD Capacity: 250GB
Hardware connection: Displayport, HDMI, USB 1.0 / 1.1, USB 2.0, USB 3.0, USB 3.1, USB-C
Product Type: Gamer PC
operating system version: Professional
Form Factor: Midi
Tower MPN: i9 9900K RTX2080Ti
Operating System: Windows 10 processor
speed: 3.60GHz Turbo 5.00GHz
Intel Core i9 9900K
Enermax Liq 240 RGB
16GB G.Skill Aegis DDR4-3000 DIMM CL16 Dual Kit
MSI Z390 Gaming Plus
250GB SSD
2TB HDD
AZZA Inferno 310
700 Watt be quiet! System Power
Windows 10 Professional
Microsoft Office 2019 Professional Plus
ilja.p
MSI B450 Carbon PRO AC
AMD Radeon RX480 4Gb Sapphire
Int
NZXT H500, Hue +
Cooler Master M2 Pro 850W
VDSL 20
Win 10 64bit/ Google Chrome
Da
Ryzen 5 1600 AF
ASROCK AB350 Pro4
2 x 8GB DDR4 2773Mhz
Phillips 24"
Cable 600/60 SBB
Mi 11 lite 5G NE
Da i od mene :D hahaha Ja imam talenat :D
Arrow
Gigabyte B450 AUROS Elite
G.Skill SniperX 2x8GB 3000MHz
Sapphire Nitro+ RX 570 4GD5
LG 21" IPS Full HD
Genius SP-HF-160 / AKG K92
Redragon Grimlock GC-602
Thermaltake Smart SE 530W
Windows 10 64-bit, Opera
Uzmi Ryzen :troll:
Salu na stranu ovo je neki prebuild? Mislim da ti je isplativije ici na i7 za gaming nego na i9..
goran1988
mislis da je bolji i7 od i9?ali iako se ne razumem grafika kida,sta onda mislis o ovome
8 GB DDR4 16 GB Optane Memory 1 TB HDD Windows 10 Home 64-Bit NVIDIA GeForce GTX 1060 6 GB GDDR5 Model Brand CyberpowerPC Model Gamer Xtreme S760 Part Number GXS760 Quick Info Type Gaming & Entertainment Usage Consumer Processor Intel Core i7-7700 3.6 GHz Processor Main Features 64 bit Quad-Core Processor Cache Per Processor 8 MB L3 Cache Memory 8 GB DDR4 + 16 GB Optane Memory Storage 1 TB HDD Optical Drive 24x DVD+-R/+-RW DUAL LAYER DRIVE Graphics NVIDIA GeForce GTX 1060 6 GB Power Supply 450W Case CYBERPOWERPC W210 Black Windowed Gaming Case Operating System Windows 10 Home 64-Bit Motherboard Chipset Intel B250 CPU CPU Type Intel Core i7 7th Gen CPU Speed 7700 (3.60 GHz) L3 Cache Per CPU 8 MB CPU Main Features 64 bit Quad-Core Processor Graphics GPU/VGA Type NVIDIA GeForce GTX 1060 Video Memory 6 GB GDDR5 Virtual Reality Ready Yes Memory Memory Capacity 8 GB DDR4 Memory Spec 4 GB x 2 Optane Memory Optane Memory 16 GB Storage HDD 1 TB HDD Interface SATA III HDD RPM 7200rpm Optical Drive Optical Drive Type DVD±RW Optical Drive Spec 24x DVD+-R/+-RW DUAL LAYER DRIVE Communications LAN Speed 10/100/1000Mbps Back Panel Ports Rear Audio Ports 3 ports Expansion PCI Slots (Available/Total) (0/1) PCI-E x16 (2/2) PCI-E x1
Arrow
LG 21" IPS Full HD
Ne bolji vec isplativiji.. U gamingu imaju manje vise iste perforamnse, a razlika u ceni bi trebala da je povelika.. :)
Tu razliku na neko kvalitetno hladjenje i kloknes i7 milina
Ryzen 5 1600 AF
ASROCK AB350 Pro4
Phillips 24"
Cable 600/60 SBB
Mi 11 lite 5G NE
SkazzY
My precious
MSI B450 Tomahawk
GTX 1050 TI
Dell P2421D
SAMA Armor 80+ Gold - 650W
Windows 10 + Linux
Kida vrv zato sto ima prvo slovo R, prvi broj 2 i na kraju TI. Pretpostavljam da je u pitanju gotova konfa cim si kopirao ovakav tekst i najverovatnije mozes dodta bolje proci da sve to sam sastavis.
goran1988
pa recimo graficka 2080 ti gddr6
goran1988
dobro,samo sam pitao za misljenje nista vise
Arrow
LG 21" IPS Full HD
Okej pocinjem da mislim da je torll posto razlika u ceni izmedju prve i druge konfe je buklvano ceo racunar solidan..
goran1988
da jeste to je gotova konfiguracija
SBB 300/30 Mbps
Windows 11 & Opera GX
Bolje nam reci budžet da uzmeš komp iz delova i sastaviš, ove prebuilt konfiguracije... bolje da ih ne komentarišem. Odrapiće te po džepu bez ikakvog razloga.
goran1988
Pa ovaj pc prvi sto sam vam poslao specifikacije kosta sa dostavom 900 $
Veljadin
Ryzen 5 5600x + LC-CC-120 RGB
ASUS TUF Gaming B550 Plus
AOC 24G2SPU/BK 23.8" 165Hz
MS Industrial Winston
Seasonic S12 ll 620W
900 dolara? 9900K sa 2080Ti? Komplet konfiguracija? Ko tu koga ...
goran1988
pa znam i meni je to malo cudno jer samo 2080 ti kosta boga oca
verovatno je tu mozda neka prevara
Ma jok...ajte molim vas.:nuts:
SkazzY
My precious
MSI B450 Tomahawk
GTX 1050 TI
Dell P2421D
Windows 10 + Linux
Ajde molim te prosvetli nas gde to kupujes.
SBB 300/30 Mbps
Ako kupiš ovo za $900, imam ja 25 metara bežičnog kabla da ti prodam po super ceni...
Veljadin
SkazzY
My precious
MSI B450 Tomahawk
GTX 1050 TI
Dell P2421D
Windows 10 + Linux
Nista, javi ovde koliko su ti cigli poslali kad stigne paket.
Ryzen 5 1600 AF
ASROCK AB350 Pro4
Phillips 24"
Cable 600/60 SBB
Mi 11 lite 5G NE
