Nexus EDGE
Nexus announced the newest addition its case lineup. The Nexus EDGE, measuring 64.2 x 23.9 x 57.6 cm (L x W x D) is a full-ATX tower, compatible with most Flex-ATX, M-ATX, ATX, and E-ATX motherboards. The case has a fine brushed-metal finish with polished, rounded-off edges. The external drive bays can be locked off behind a metal front-door. Although the exterior reveals 13 5.25" bays, only 8 of them are accessible. The bottom five bay covers protect the 4-bay 3.5" drive cage inside, which neighbours two 2-bay drive racks that hang above the PSU area. This area is separated from the motherboard area, and shares room for a 120 mm fan with it.
The motherboard tray has room for 7 expansion slots. It has an opening where most motherboards have the CPU socket, which provides accessibility to CPU coolers with bolt-through retention mechanisms. Another 120 mm fan bay is located above the rear-panel, an a 140 mm fan to ventilate the entire case from its top. The case provides a degree of noise control with its noise-absorbtion wave foam padding. The utility panel is located on the top, and is a standard issue with a couple of USB ports, an eSATA port, and audio connectors. The Nexus EDGE is expected to retail for around 160 EUR.
izvor
BigJoe
Intel DX58SO
3x2GB OCZ Reaper 1600 CL7
ATi Radeon HD5850 by GA
SAMSUNG SM 206BW
~3,5TB
Realtek ALC889
TT ToughPower 1500W
Logitech MX1000 + G500 + G11
ADSL 4Mb/256Kb
Windows 7 x64
Deluje veoma zanimljivo, bas dosta stvari bi se moglo spakovati unutra.
TheBear
Gigabyte Z490 UD
XFX RX 580 8GB
Samsung P2450H 24"
Logitech X-530 5.1
Cooler Master ATCS 840 Black
Cooler Master V700 700W
Samsung SH-223F
100/8 Mb/s
Ogromno kuciste, a i dobro izgleda ima mnogo mesta za ventialtore i komponente bas je veliko...
Cim sam ga ugledao na tcmagazinu, kuciste mi se mnooooooooogooooooooooooo svidelo :) Ekstra je i za modovanje, i kao sto kaze djole bas moze da se napakuje gomila stvari :)
Oki
Cena je ...pa zadovoljavajucja. Dao bih 160e za ovako kucjishte definitivno. Da je 200 - ne bih :d
Moze:)
Ti daj 160,pa se razocaraj,i prodaj ga meni za 90 i svi smo srecni:d:d
Kuciste je skroz dobro,mozda je mogla unutrasnjost da bude crna,al Boze moj...Svidja mi se sto je ogromno i prostrano a i spolja izgleda dosta elegantno:cool:
activated1
a1-PC
ASUS M5A99X EVO
4x4GB Kingston HyperX Genesis
BenQ 2450
Corsair Obsidian 750D
Corsair RM1000i
Telekom VDSL 20Mbps/4Mbps
Meni se vrlo vrlo dja, i prostrano i ta vrata napred bash izgleda mocno kuciste :)
32GB Corsair DDR5-6000 CL30
Corsair Frame 4000D RS
E ovo je već fino... Sviđa mi se prostranost, izolacija, dizajn, samo još da vidimo kakav je sistem za montiranje hard diskova u praksi i može da dobije "possible buy" sertifikat :D
Pa sta znam, deluje ok, pravljeno je kao stari Chieftec Big Toweri, znaci visoko je, al ako je cena 160eur, pre bi uzeo Antec 1200, razlika je u nijansama, ala izolacija.
Bolje resen cage za hdd-ove na Nexus-u, 1200 je ruzan do zla boga, gledao sam ga 3 dana i skontao da ne vredi te pare....
Flight
Chieftec Prostreet Rev. 3.0
Meni se ne svidja kako izlgeda unutrasnjost i oni sundjeri za izolaciju, to dodatno zagreva kuciste. Ali sve u svemu dobro kuciste i ima 14-cu pozadi za izbacivanje vazduha + 12-cu, sto je lepo, mora se priznati, prorez iza CPU-a na ploci, mada za te pare bar moze da se bira kuciste.
Shiki
4GB DDR3 1066MHz
LG LC55 42"
Logitech Z5500
Cable 8096/384
Snow Leopard 10.6.6 :)
Macbook White Unibody
Rekao bih po slikama da je nexus dobrano veci od 1200-tke... Mislim da bolesno vodeno moze da se napakuje unutra i onda bi stvarno bilo full-fullova :)
Flight
Posteno, za potrebe vodenog Nexus stvarno pruza mnogo (prostora :)), dok 1200-ka, stvarno ruzno kuciste pa nema gde vise.
audiofreak
Intel DX58SO BIOS 4196
Apacer 6GB DDR3/1333
19" Viewsonic VP930b
Cooler Master CM-690
Chieftec APS-650C
Pioneer DVR216DBK
Telekom 4Mbit ADSL
Windows XP SP3
Plantronics Voyager PRO
Meni se ne svidja sistem montaze diskova ni njihova pozicija. Uvek moraju bar nesto da useru.
Nexus Edge : 642mm x 239mm x 576mm (L x W x D)
Chieftec BA-02B : 650mm x 250mm x 530mm (H x W x D)
Antec 1200 : 582mm x 213mm x 513mm (H x W x D)
Rekoh ja da mi deluje visoko kao stari Chieftec big toweri.
Shiki
4GB DDR3 1066MHz
LG LC55 42"
Logitech Z5500
Cable 8096/384
Lepo sam ocenio da je daleko vece od Anteca :), i to "na svaku stranu" :)
