Izbor case fan-a
32GB Corsair DDR5-6000 CL30
Corsair Frame 4000D RS
dadoo
Gigabyte GTX 750Ti
LG IPS224
Sennheiser HD598
@ays:
Da, za sve.. Ja sam se licno nameracio na Obsidiana :)
@Vule
Ni jedno ni drugo.. ja sam Product Menager :)
Conclusion
From this review we can see that Noiseblocker Black Silent fans are definitely a good choice when buying a performance cooling solution for your much loved rig. I’m not too keen on the XL1 or XLP fans as there’s little performance gain from those when compared with the XL2. However if you’re the type of user where every degree counts, you’d probably much rather go for the XL2 or XLP. But for noise conscious system builders, the XL1 is definitely the best choice.
Pros
  • Aesthetically Pleasing
  • Include Anti-Vibration Pegs
  • Robust Frames
  • Well Priced
  • Perform Very Well
  • XL1 = Dead Silent
@dadoo:
:) Daj mi onda ubrzaj malo tu proceduru oko vraćanja Anteca 300 i uplaćivanja novaca na račun, pokušavam već 3 dana da se sporazumem za raznim ljudima tamo u prodavnici br.1, ali baš teško ide, nikako da mi se neko javi sa rešenjem, pošto mi je preko sitija poslato kućište... Ako imaš kakav info o tome, baci im neku buvu kao hitno je, brzo njemu rešavajte :D :D
ays
@ays:
@Vule
Uhu, nice! Obsidian je jedan od boljih izbora ako nameravaš da staviš tečno hladjenje. Na gornju stranicu jedan 3x120 radijator i milina!
Molim nadležne iz PCAxe tima da se gos'nu dadoo dodeli custom "titula" G-Manager! :d
dadoo
Gigabyte GTX 750Ti
LG IPS224
Sennheiser HD598
hahahahaha to mu dodje kao Gospodin Menadzer :D
Nisam planirao vodeno hladjenje.. nemam neke velike grejalice u racunaru.. mislim da ce to raditi na vazduhu
Pike
Intel i7-4790K @ 4.7GHz / Megahalems Black lapped by Pike
ASUS Maximus VII HERO
Kingston HyperX FURY Black DDR3 2x8GB @ 2000MHz
NVIDIA GeForce GTX 980
ASUS PG278Q ROG Swift
SAMSUNG 850 PRO 256GB & WD Black 1TB
M-AUDIO Studiophile AV 40
Corsair Obsidian 650D
Seasonic Platinum SS-660XP2
Roccat Kone Pure & Logitech Illuminated Keyboard
Windows 10 Pro x64
Odusevljen sam ovim sto vidim, jel ima nesto i kod Vuka ili da palim na B. Brdo ?
dadoo
Gigabyte GTX 750Ti
LG IPS224
Sennheiser HD598
kod Vuka ima manja kolicina al je izlozena... Na Brdu ima gomila toga al je i dalje sve u kutijama (upravo mi je bio dekara pa smo malo rovarili po njima)... U toku je preseljenje pola radnje u novootvorenu, pa ce u tom praznem delu biti izlozena ova nova roba.. e sad kada.. pojma nemam
Pike
Windows 10 Pro x64
Idem kod Vuka da im ispraznim radnju. :D
Hvala
Dekara
OC Guru
Nisam izdrzao:), otisao sam odmah po XL1, Hector me upoznao sa dadoom;) i kao sto sam i ocekivao XL1 je necujan na 1000rpm, mislim da ce i najveci fanovi apsolutne tisine biti zadovoljni ovim ventilatorom.
Da se dopunim za XL2, definitivno nije supersilent i nece zadovoljiti po pitanju buke fanove apsolutne tisine ali sve ostale kojima ne smeta "lagan" huk ventilatora definitivno hoce! Odnos protoka vazduha i buke mu je odlican pa svako kome ne smeta lagan huk ventilatora treba da razmisli o njemu.
pa noiseblocker :)
steta sto nema i multiframe m12
dadoo
Gigabyte GTX 750Ti
LG IPS224
Sennheiser HD598
brate kad si ga pre namontirao! elem, uzecu i ja jedan veceras pa cu ga uporediti sa sharkoon-om SE 1000
Dekara
OC Guru
Da, Sharkoon sam video uzivo, brutalno izgleda, cenim da biti mrtva trka u performansama ali estetski je Sharkoon pocistio patos sa svima.
Znači da poručujem 2xXL1 za kućište?
Dekara
OC Guru
Paaaaaa, moj subjektivni utisak je da je ovo supersilent, meni bi odgovarao i NB na ~1200rpm a cenim da je ovo dovoljno silent za sve ukuse. Na moju odgovornost narucuj pa ako se razocaras pisi mi - :D
Pike
Windows 10 Pro x64
Nisam se vratio praznih saka. :D
Uzeo dva (((Noiseblocker))) XL1 i dva Sharkoon Silent Eagle SE kod kojih sam odusevljen modularnim kablicima za razlicite brzine. :)
Nista nije bilo izlozeno, vec u 3 ogromne kutije pa lepo mi to tras na pod pa biraj. Momak koji je radio je Car odusevio se sta im je stiglo koliko i ja.
Sta je u kutijama bolje da ne znate, sve sama egzotika nikad vidjena kod nas. :balavim: Od raznih sitnica za moding kojih nema na sajtu do TRUE Copper teskog 2kg. :balavim:
ays
Ja ću ipak da sačekam da dovuku Enermax Magma ventilatore. :d
A do tada... Živeo Caseking! :D
dadoo
Gigabyte GTX 750Ti
LG IPS224
Sennheiser HD598
Magma je porucena za drugu turu..
Igrao sam se sinoc malo sa ventovima.. Noiseblocker je definitivno pobednik sto se tice tisine, ali Sharkoon ima vec protok i bolje duva (ali se zato vise i cuje).. Da se razumemo, to je i dalje vrlo tiho, ali meni je zvucna granica malo pomerena pa cujem i ono sto ne bi trebalo :D
... zadrzacu Noctua-u...
Oki
Ih bre dadoo pa na pola sam koraka da prodam sve moje noktue i da pazirm neshto iz ove ponude..da li mislish da se isplati raditi tako neshto ?
imam i s12 i p12 ..
Shiki
4GB DDR3 1066MHz
LG LC55 42"
Logitech Z5500
Cable 8096/384
Snow Leopard 10.6.6 :)
Macbook White Unibody
Ne znam koliko su tihi ostali, ali ta Noctua S12 je za case fan extra, mislim da bi bilo cisto bacanje para da neshto menjash ;)
Hector Ruiz
Intel i5 4670K@ Megahalem
ASUS Maximus VI Hero
Intel HD4600
Samsung P2470H
microlab Solo6C
Corsair 800D
Seasonic X-850 SS-850KM
Kablovska
Windows 8.1 64bit
Znas kako, svi volimo da probamo nesto novo. Evo ja se sad lozim da uzmem Corsair Obsidian iako mi je i ovo kuciste vise nego dobro.
Shiki
4GB DDR3 1066MHz
LG LC55 42"
Logitech Z5500
Cable 8096/384
Ma pusti mene, pokushavam da izigravam glas razuma :d a da imam pare prvi bih verovatno promenio :d
dadoo
Gigabyte GTX 750Ti
LG IPS224
Sennheiser HD598
Mora da pohvalim gigatron svaka cast ;) :wave:
Hector Ruiz
Intel HD4600
Samsung P2470H
microlab Solo6C
Corsair 800D
Kablovska
Windows 8.1 64bit
Info za sve: garancija za robu sa casekinga je 2 godine na svaki artikal. Nazalost toliko nama daje svaba.
dadoo
Gigabyte GTX 750Ti
LG IPS224
Sennheiser HD598
