EVGA Interview Dual Monitor System Review
Hector Ruiz
Intel i5 4670K@ Megahalem
ASUS Maximus VI Hero
Intel HD4600
Samsung P2470H
microlab Solo6C
Corsair 800D
Seasonic X-850 SS-850KM
Kablovska
Windows 8.1 64bit
EVGA keeps growing its visual-computing product lineup by the day, and has made its first major product in the PC display a reality. The InterView 1700 is a dual-panel display that holds two LCD panels side-by-side. The two panels are suspended on a central frame with joints that allow them to individually turn 180 degrees, and fold 90 degrees, so the viewer can customise the viewing experience. What's more, the frame itself bends 180 degrees.
Each panel is 17 inch widescreen LCD, with native resolution of 1440 x 900 pixels, response time of 8 m, and 500:1 static contrast ratio. The central frame holds a 1.3 megapixel web-cam built in. It takes input from dual-link DVI and HDMI. At US $650, the EVGA InterView 1700 is targeted at financial analysts, accountants, scientific installations, medical imaging, and other professionals.
Source: HotHardware
BigJoe
Intel DX58SO
3x2GB OCZ Reaper 1600 CL7
ATi Radeon HD5850 by GA
SAMSUNG SM 206BW
~3,5TB
Realtek ALC889
TT ToughPower 1500W
Logitech MX1000 + G500 + G11
ADSL 4Mb/256Kb
Windows 7 x64
Odlicno resenje, mana bi mogla biti samo sto su dijagonale monitora male. Ali svakako veoma upotrebljivo za CAD crtanje.
Typhoon.X
Seraphim/Azrael
X570 Aorus Elite
DeLL G3223D
FX-AUDIO DAC-X6
NZXT H710
CM V1200 Platinum
Xternal LG GP08NU6W
SBB Cable 350/35
Definitivno preskupo, a i mislim da je visina premala za neki ozbiljniji rad u CAD-u...
Shiki
4GB DDR3 1066MHz
LG LC55 42"
Logitech Z5500
Cable 8096/384
Snow Leopard 10.6.6 :)
Macbook White Unibody
Neka, prvi su se setili, sad samo da krenu i ostali proizvodjaci da se razvijaju u tom pravcu i svi srecni, pashce cene brzo a imacemo daleko bolje proizvode ;)
