EVGA Classified SR-2 1200W Power Supply
EVGA, in its pursuit to deliver only the best quality and performance, is at it again with the EVGA Classified SR-2 Power Supply. Delivering 1200 watts of continuous power while maintaining an 80 Plus Silver certification is only the beginning. 6 +12v rails capable of delivering 38A, and fine-tuning knobs allow you to adjust the +12v rail and fanspeed to the optimal performance.
This power supply is designed around the record shattering EVGA Classified SR-2 motherboard, but is perfectly suited to meet and exceed the needs of any motherboard and graphics card combination!
Continuous Power means this PSU is rated in continuous power; the steady power a PSU can output continuously, rather than the amount delivered at its short-lived peak. Also, Advanced Hybrid Cable Management combines traditional and modular PSU designs, and achieves low wire-transmission loss as well as better cable management for improved airflow. PowerCache means this PSU has a high-performance capacitor that delivers an extra power reserve when needed. And Extreme Voltage and Fan Tuning offers the ability to fine tune your +12v voltage and power supply cooling fan to suite any condition, whether you are pushing to the limits or just running silent.
Izvor: EVGA.com
BigJoe
Intel DX58SO
3x2GB OCZ Reaper 1600 CL7
ATi Radeon HD5850 by GA
SAMSUNG SM 206BW
~3,5TB
Realtek ALC889
TT ToughPower 1500W
Logitech MX1000 + G500 + G11
ADSL 4Mb/256Kb
Windows 7 x64
Zanimljivo :)
Jel mi se čini ili je ovo neki Antec unutra?
otprilike ;)
miha
Debian
cek bre... a sto je ovaj konektor koji ide u 220 ovakav?? to neki novi standard?
Diabolique
E5200
P5Q
2x2GB
DIY Projektor
10001FALS, 10EACS, 10EADS
Audigy@Z5500
Generic
CM 450 RP
Pioneer 215D
MS Natural 4000, MX1100R
IKOM 2Mb
Win XP
Taj srandard se koristi za uređaje veće snage.
APC na svoje UPS-eve veće snage stavlja ovaj konektor, a i neka napajanja koriste isti.
miha
Debian
od koliko W ga stavljaju? preko 1KW?
Diabolique
E5200
P5Q
2x2GB
DIY Projektor
Audigy@Z5500
Generic
CM 450 RP
Pioneer 215D
IKOM 2Mb
Win XP
Ne sećam se tačno, APC stavlja na 1200 ili 1500 i jače, dok za napajanja zavisi od proizvođača.
BigJoe
Intel DX58SO
SAMSUNG SM 206BW
~3,5TB
Realtek ALC889
TT ToughPower 1500W
ADSL 4Mb/256Kb
Windows 7 x64
Upravo ja imam TT TP 1500W i ima standardan euro džek pozadi, samo je kabl velikog preseka.
takodje, i na Cooler Master M1000 sam imao standardni prikljucak..
za 1500w se mozda stavlja on
mozda je shamino samo doterao nesto ako je imalo sta da se dotera :D ali dosta je skuplje od anteca izgleda
CAR
Gigabyte EX58-UD5
Samsung SyncMaster T220
Cooler Master Cosmos S
Samsung SH-S203B
aDSL 1024/128
M
Misko78
Guest
Taj konektor tj C20 je deklarisan na 16A za razliku od C14 koji je "samo" 10A. I da budem blag je sviranje onoj stvari. W=I*V stoga ako vam napajanje vuče 2000W pri 230V koliko je kod nas napon ispada 8,69A što je u standardu C14.
Kod mene na 1100W CM je C20
