Cooler Master Storm Sniper
activated1
a1-PC
ASUS M5A99X EVO
4x4GB Kingston HyperX Genesis
BenQ 2450
Corsair Obsidian 750D
Corsair RM1000i
Telekom VDSL 20Mbps/4Mbps
Model: CM Storm Sniper
Case Type: Steel, ABS Plastic, Mesh bezel
Net Weight: 10.6 kg / 23.42 lb
Dimension: (D)566.6 x (W)254.6 X (H)551 mm / (D)22.3 x (W)10 x (H)21.7 inch
Material: Steel, ABS Plastic, Mesh bezel
Color: Black
Cooling System: Front: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA)Top: 200x30mm Blue LED Fan x 1 (500 - 1000rpm, 17 - 23 dBA)(can be swapped for two 120mm fans or 120x240mm Radiator)Rear: 120x25mm Standard Fan x 1 (1200rpm, 17 dBA)(can be swapped for 90mm fan or 80mm fan)Bottom: Supports 140mm Fan x 1 or 120mm Fan x 1 w/ Dust Filter (optional)Side: Supports 200x30mm Fan x 1 (optional)120x25mm Fan x 2 (optional)
Motherboards: Micro-ATX/ATX
Drive Bays: 5x 5.25" Exposed (without the use of exposed 3.5 inch Drive Bay), 5x 3.5" Hidden & 1x 3.5" Exposed (converted from one 5.25 inch Drive Bay)
Front I/O: USB2.0 x 4; IEEE1394 x 1; eSATA x 1; Mic x 1; HD Audio+AC'97 x 1
Expansion Slots: 7 + 1
Review
Asus Z690G-Gaming Wifi
AsRock RX6900XT OC Formula
BenQ EX2780Q/Hisense 65u8gq
LIAN LI PC-O11D Mini TG black
Optika 400/80
Po meni najlepshe CM kucishte ;) da ima full tower mozda bi ga i uzeo :)
Sa ovim nogama nameštenim ovako kao na slici baš podseća na vojnika u stavu mirno..
Inače, lepo i funkcionalno kućište, u svakom slučaju ide u grupu non'silent mašina
Shiki
4GB DDR3 1066MHz
LG LC55 42"
Logitech Z5500
Cable 8096/384
Snow Leopard 10.6.6 :)
Macbook White Unibody
Cini mi se da je Dule rekao da je izuzetno tiho ;), plus ima regulator obrtaja!
Jedino shto mene odvlaci je cena od nekih 170 jevropskih jedinica ;)
Ima regulator i na minimumu spada u silent rešenja ali protoka vazduha nema a ako se postavi na max, dobija se solidna buka. Opet, buka je subjektivanm osećaj tako da sa te strane može nekom biti silent na max ali može nekom drugom biti bučno i na min.
Poenta ovoga jeste, da ako neko traži isključivo silent rešenje, treba da se kloni ovoga dok svi ostali, slobodno, kućište je odlično, sem možda cene
