Thermaltake Level 10
Earlier this year, Thermaltake wowed us all with the announcement of the Level 10, a concept case designed in conjunction with BMW DesignWorks. Rather than a standard aluminum box, the Thermaltake Level 10 would incorporate a central pillar, with individual compartments hanging from it for the motherboard, PSU, optical drives, and hard drives. Here's a press shot of the Level 10.
The Level 10. It's high-concept!
We haven't heard much about the Level 10 since Computex in June; we were even a bit skeptical that such an outré case would ever come to market. But Friday morning we strolled into our secret lair to find an enormous box on our doorstep. After a hasty unboxing (documented on Page 2), we found a Level 10 of our very own, which we promptly shipped upstairs to our in-house photographers.
The Thermaltake Level 10 in all its glory.
As you can see, the production Level 10 is nearly identical to the concept shots we've seen earlier. Each compartment on the Level 10 has its own ventilation. The large panels on the lower left cover the motherboard mount, PCI-E cards, GPUs, and so forth. The six slots on the right are hot-swap SATA bays, connected to a large vertical heatsink. The bays have mounts for 3.5-inch and 2.5-inch drives. The top right box holds three optical drives, and the upper left box holds the power supply.
We didn't have time to hook up all the lights, but the Level 10 includes a red LED strip that runs from the case's front panel across the top and to the rear, as well as red LED intake and exhaust fans in the motherboard compartment. Each of the six SATA hard drive bays includes a red LED that lights when the bay is occupied (we stuck a hard drive in the top one to show how it works).
The Level 10 with power supply, motherboard, optical drive, and three hard drive bays open.
The locks on the rear panel keep the component bays secure.
The upper right lock secures the PSU and motherboard compartments,
while the left locks the hard drive trays and optical drive bays.
The guts of the Level 10: individual compartments keep components thermally isolated. And it looks wicked.
The right side panel on the Level 10 comes off for access to the rear of the motherboard tray, just like on a standard case. Note the holes for cable routing as well as the backplane cutout for installing CPU coolers.
Now, step back with us in time as we show our initial unboxing of the Level 10, and give our first impressions of the case.
The Level 10 will be available in mid-October for $700.
Diabolique
E5200
P5Q
2x2GB
DIY Projektor
10001FALS, 10EACS, 10EADS
Audigy@Z5500
Generic
CM 450 RP
Pioneer 215D
MS Natural 4000, MX1100R
IKOM 2Mb
Win XP
Odličan dizan.
Da je bar duplo jeftinije, bilo bi hit.
Ovako ostaje samo patkometrija.
