Asus Z690G-Gaming Wifi
AsRock RX6900XT OC Formula
BenQ EX2780Q/Hisense 65u8gq
LIAN LI PC-O11D Mini TG black
Optika 400/80
Scythe is designing a new VGA cooler aimed at broad compatibility and a relatively compact built. The Scythe Setsugen will be the first VGA cooler from Scythe to formally support NVIDIA GeForce GTX 2x0. It uses a slightly smaller, slimmer overall design, and makes use of the recently announced Slip Stream 120 mm fan, which enables the cooler to stay within the limits of two expansion slots.
Its construction involves a copper GPU contact block from which four heat-pipes arise. Two heatpipes make convey heat to an aluminum fin block each (two in all). The blocks make an enclosure for the Slip Stream fan to stay closest to the GPU, blowing air away from the PCB, rather than on it. The kit includes heatsink for the NVIO2 processor and a heatsink that matches the VRM area of the P651 PCB, along with heatsinks for the memory. The cooler will remain compatible with most other GPUs from NVIDIA and ATI. Scythe is expected to announce this soon.
Source
