Scythe Gentle Typhoon No.1 Radiatorski i Case Fan
vlada.j011
Phenom II X4 965BE + CORSAIR H70 (i7-2700k)
Crosshair 4 Formula (eVGA Z77 FTW)
KHX Grey 2x2GB CORSAIR Airflow 2 (CMT16GX3M4X2133C9)
HD 5870 2GB
Samsung P2450H
Kingston SSD V+ 64GB + WD 500AAKS, LG HXD5U25GLS External HDD
Creative Inspire T5900 5.1
CORSAIR Obsidian 650D
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Windows 7 Ultimate x64
Logitech C310 WebCam, LG 250GB External HDD
Informacije o ventilatoru koga Srbija nije videla koji je D A L E K O najbolji radiatorski fan a naravnoi ako je dobar za radiator dobar je i kao intake case fan.
High Performance Design
Gentle Typhoon 120 mm High Speed Series is optimized for high speed as well as high airflow. Implemented ring connects the fan blades creating PQ characteristics similar to 38 mm thickness fans, yet improving in regard to noise.
Optimized for High Airflow
Forceful airflow is being created and guided in a linear fashion thanks to the stabilizing ring implemented in the Gentle Typhoon 120 mm High Speed Fans. By using this powerful design the fans are able to generate high pressure to overcome and handle high resistance such as when being used with a duct or coolers with dense fin structure.
Vibration Reduction Structure
By employing a large fan motor, little fluctuation in rotation torque have been achieved. Furthermore a vibration absorbing structure has been integrated to further reduce the noise level. This combination reduces the transfer of vibration from motor to the fan chassis greatly.
Silent 120mm Case Fan
D1225C12B1AP-11 (500 rpm) - 0.015 A - 5 dBA - 31 m³/h
D1225C12B2AP-12 (800 rpm) - 0.023 A - 9 dBA - 48 m³/h
D1225C12B3AP-13 (1150 rpm) - 0.034 A - 16 dBA - 63 m³/h
D1225C12B4AP-14 (1450 rpm) - 0.049 A - 21 dBA - 85 m³/h
D1225C12B5AP-15 (1850 rpm) - 0.083 A - 28 dBA - 98 m³/h
-4-Pin Molex Connector with additional 3-Pin Fan Speed Signal Connector
-100.000 h / 35°C or 60.000 h / 60°C
-Double Ball Bearing
Nidec Servo Corporation (Japan)
AP-14 1450RPM
http://youtu.be/Yuj7GZqNpOs
AP-15 1850RPM
http://youtu.be/rm6jlrqifQE
Kao sto vidite 1450RPM ne najbrzi je idealan za besuman Case Fan a pogledajte samo kakav je to potisak koji je tik ispod Noiseblocker Multiframe od 1800RPM i moze sluziti bolje od CORSAIR Fanova koji dolaze uz Hydro seriju, znaci bolje hladi. Da ne govorimo da i 1850RPM model koji je isto jedva cujan a vec bi prebacio daleko Performanse Noiseblockera Multiframe.
AP-15 na 4x120mm Radiatoru
http://youtu.be/vPpD1k1iSVc
AP-15 na H50 push-pull
http://youtu.be/A9M30SiZ5Ng
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
GentleTyphoon 120 mm High Speed Fan Series
D1225C12B7AP-29 (3,000 rpm) - 36.5 dBA - 83.0 CFM = 141 m³/h - 2.64 W - 0.22 A
D1225C12B9AP-30 (4,250 rpm) - 44.0dBA - 116.5 CFM = 198 m³/h - 6.72 W - 0.56 A
D1225C12BBAP-31 (5,400 rpm) - 50.5dBA - 150.1 CFM = 255 m³/h - 13.68 W - 1.14 A
AP-31 (5400RPM) Fan Controller Push-Pull na H50
http://youtu.be/DlKSQgarMSc
-12 V (DC)
AP-29 (3000RPM)
http://youtu.be/nJQw9Gz1vME
AP-31 (5400RPM)
http://youtu.be/tlDv0XL5bv8
AP-31 5400 na kontroleru
http://youtu.be/L1vNo2CRlcs
Po meni najbolje resenje za Radiatore i overklockerski fan.
Pa ako hocete da hladite a ne da pirkate i da ukrasavate izvolte.
To vam je cena 2.5 neka krs osrednja ili 3 zadnji krs ventilatora.
Moj zakljucaj je sledeci
Radiatori i Hydro series model AP-29 (3000RPM) i kontroler
Veliki Radiatori 3x120mm, 4x120mm AP-15 (1850RPM) kontroler moze i ne mora
Case Intake AP-14 (1450RPM)sa kontrolorom ili AP-13(1150RPM) bez ikakve kontrole hladi kao manijak a tisina.
Ili se igrajte sarenim igrackicama u bojama Made in China.
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Gentle Typhoon Modovani
Na grafikonu gore napravljena je mala greska tj Noiseblocker Multiframe M12-S3HS koji pise da se vrti na 1080 obrtaja u stvari radi na 1800RPM
a gotovo je isti kao AP-14 od 1450RPM.
NE KUPUJTE GLUPOSTI NEGO VENTILATORE!
Cim bude para bice ovih ventilatora :)
Nemam ja ove TT ventove od 300din zato sto volim nego zato sto moram ali za 300din su predobri
Kad bude para eto i tajfuna :wave:
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Ovaj ventilator kosta kao i Noctua i kao i neki Enermax Apolish i neki Sharkoon ili 200din vise.
Njegova cena je od 1470-1750din zavisi od prodavnice do prodavnice i oko 1900 din za high speed modele.
Opravdanja nema zasto ima Noctua koja je bucnija i losija i za Intake i za radiator a 200din gore dole.
Bitno da ja sada uzimam 2 kom black i posle kada bude sledeca narudzbina jos 2 komada 1450RPM za kuciste pod uslovom da saznam kako ih otvaraju da ofarbam i te u crno. Drugi nek uzimaj usta hoce, Arctic, Noctua sta zele, nije moj problem.
Bice mnogo lepsi kada ih ja ofarbam u crno nego fabricki.
I Ram i Ventilator u mat crnu.
Bas sam trazio da vidim kako ih skinu sa ovoga.
Mislim da jedino nisu pogodni za izbacivanje iz kucista.
Za to treba nesto sporo i verovatno drugaciji tip.
Mada imaju oni model i 500RPM i 800RPM oni ne proizvode zvuk verovatno.
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Sada gledam Noctua je 16e.
Losija je najmanje 15% od ovog a bucnija isto toliko a ruznija 150%.
Takve gluposti se donose po 2000 din prodaju a skoro dve godine niko nije seo da kaze da vidim onajbolji radiatorski i intake fan da dobavimo.
Nema na popustima trazeni su, svi se rasprodaju i drze cenu ne moze da se nabavi na ko zna kojim popustima a prodaje kao da je juce se pojavilo a ne pre 3-4 god.
Koje nema pare. Za ASUS MARS II ima pare narod i ARES.
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Ljudi trebace mi pomoc mala kada budem dobio Gentle Typhoon da ga pretvorim u PWM Fan.
Da li neko zna da li je ovo komplikovano raditi
http://www.overclockers.com/high-speed-gentle-typhoon-pwm-mod
Cisto da bi moglo da mi ocitava na maticnoj ploci.
Treba mi samo jos 2x female fan pin
i 2x 4pin konektor.
Ajao! Najbolji rad fanovi nisu PWM? Ajao! Pa kako mogu biti najbolji onda? Čak i Noctua ima PWM fanove....
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Ma daj bre ne zezaj jel problem to uraditi ili ne.
Jel znas kako se moduje molex na 7V necu da narucujem one sive da ih farbam.
Maa onaj moze na 100%
Mada ima i sivi najbrzi tacno onaj koji bi uzeo.
Ajde dajte neko resenje treba mi crni GT fan.
Da njegov molex stavim na modovan molex od 7V.
Jel tako moze. Treba mi 70-80% brzine ne tacno ono sa kontrolerom da namestam.
Mislim jel tebi jasno iz prilozenog sta je lik uradio???
Znate sta su uradili Gentle Typhoon postoji vec godinu dana i vise brzina od 2150RPM mada isto sivi.
Ali taj fan se ne izvozi ni u Ameriku ni u Evropu.
Ljudi se skupljaju na Overclock.net pa uvoze ne znam kako gomila njih od proizvodjaca.
100-200-1000 otkud znam. Jel proizvodjac sam ne salje na adrese po EVropi i USA.
To je ono savrseno sto sam rekao kada bi bilo, ima dosetili su se da je na 1850 necujan i da su mogli vise ali je cena 42$ ja video na nekom sajtu.
Ne bi toliko platio za 200RPM vise. I ni oznaka mu nije kao ovi AP nego neka deseta.
Moram imati crni GT.
Razumes gledao sam onaj video i na 7V je ono idealno bas kako mi treba.
Osmislite mi 7V za GT najlakse i najbezbolnije.
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Cuo sam da su i testiranja radjena i da je za 140mm radiator najbolji ventilator bio Gentle Typhoon AP-15 120mm s adapterom da pasuje na 140mm.
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
OCz
Gigabyte P55A-UD6
12GB Mushkin & Exceleram
Palit StormX GTX 1050
LG 32LK450
Corsair Obsidian 650D
Thermaltake Smart SE 530W
Nemam
Imam
Windows 8 Pro x64
Sutra treba da mi stignu 2kom. 1850RPM verzije. Kako vam se cine Noktua boje ? Razmisljam se da ga prefarbam posto nisam neki fan orig. boja.
ovo ili ovo ? Meni se iskreno prva opcija vise dopada, jedino ne znam hocu li uspeti na nadjem sprej u toj "bela kafa" boji. Ili mozda prva opcija ali obrnuto, lopatice u bela kafa, ram u crno ? Ima li nekog spretnog u PS-u da ga ne mrzi da odradi tu kombinaciju ?
c-p-r
Ovo treba uramiti, neko zeli da farba u Noktuine boje. :)
Ja kako gledam trebao bi da radis ono sto se tebi najvise dopada. :)
OCz
Gigabyte P55A-UD6
LG 32LK450
Nemam
Imam
Windows 8 Pro x64
Pa bas fore radi :)
Mada kazem, vise mi se dopada kombinacija crnih lopatica i krem rama.
prvo definitivno .. odlicno je + vanila i crna kombinacija sliva :D :P da polizes prste xD
OCz
Gigabyte P55A-UD6
LG 32LK450
Nemam
Imam
Windows 8 Pro x64
Udomnjeni :P
Kroz koji dan ih farbam i sleeve-ujem.
Inace jesu li toliko dobri koliko se prica ? Pa onako, poprilicno. Tisi su definitivno od vecine, u poredjenju sa CM SickleFlow 2000RPM tisi su pri istom RPM (ne samo pri 2000RPM, vec i pri 1000-1200-1400-1600), a pomeraju slicnu kolicinu vazduha, mozda cak i malcice vise. No kao i kod 90% fanova sa recimo 20-30cm su u ambientu skoro poptuno necujni na ~900-1000RPM. Mada se mogu poterati nesto vise a da budu skoro silent sa pola metra i dalje (do recimo 1100-1150RPM, vecina 120mm ventova ne ostaje toliko tiha na tim obrtajima). Vise je fora sto kada se stave na hladnjak ili radijator, bez obzira sto im je motor tih na 1200RPM, krenuce da prave huk vazduha pri toj brzini o rebra koji ce se cuti, to je neizbezno.
Dosta ishajpovan vent, nije iz raja dosao mada je svakako dobar i za preporuku ..
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Ja sam vam rekao, slusajte vi mene. Bitno je da nema vrrrrmmmmm koje ima i Noiseblocker M12-P vec na 1700RPM. To sto huci radiator e pa mora da huci tacno da iz vakuma guras vazduh a ne da se ventilator okrece. Ili nek huci ili nema hladjenja to je neizvodljivo da vazduh koji hladi prolazi a da se ne cuje. To jedino da je u minusu -30 duva pomalo i ledi sve ali to ne moze.
Jako su teski da se nadju, u USA ih placaju po 30$ komada. Cak i 45$ model od 2150RPM kog nema na EU I USA trzistu.
Ne uvoze ga jbg. On nema AP oznaju na kraju ja mislim.
Evo dobili su na PPC i one modele koje nisu imali. Ja sledeci put narucujem jos 1 ili 2 za kuciste.
Verovatno od 1450RPM za resistor. Kazu ljudi da je mogla mozda ta plastika da bude bolji kvalitet i to kao sto je Noiseblocker znaci vidis ga da je prema ostalima klasa iznad cak i prema Noctua.
Pa pogledajte lika sa klipom na radiatoru 6 ili 8 kompada push-pull znaci tisina potpuna samo cujes kako vazduh zaglusuje mikrofon i nista vise.
Ja se ne zezam vise sa ventilatorima. Nema kupovine zbog izgleda, da kupujem gluposti.
Ofarbacu ih potpuno u crno jel ta boja nece dosaditi i moze na bilo koju kombinaciju.
Ti napisi samo cime si farbao. Ja imam MOTIP Swartz Mat Acryl. Mozda bi trebao da kupim MOTIP Primer prvo.
Da jel ces ceo da sleevujes ili ces da sleevujes kao sto kupovni Noctua ima.
Mislim da ovde nije dobro ici do kraja do motora zbog prijanjanja na povrsinu.
Pogotovu za radiator.
Kad pogledas mozes i da ga ostavis jedno 10 dana tako cisto da malo tu boju imas.
Nema sta da je ishajpovan vent nije lep da se kaze uzima ga zaato neko, ruzan je.
Ali najbolje odradjuje posao ljudima sa radiatorima. Pa Martin je tistirao onaj sto sve vent testira i na 140mm radiatoru najbolji fan je GT AP-15 sa adapterom iako je 120mm.
Ventilator je napravljen 2008 imali su vremena da naprave stvarno bas bolje.
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Da recimo eto CM je popularan ovde ali nema neki dobri ventilatori od njega. Ja sam kupio poslednja dva u gradu pre godinu ipo dana 140mm Blue Led od tad ih nema. Sickle Flo kazes dobar je a nema ga. XtraFlo je kazu ljudi predobar-800-2200RPM Red Led jako cudne cool propelere.
Mislim da se dobija sa V6GT a prodaje se i ovako, nema ni njega, Blade Master 600-2000RPM idealan za Hyper 212+ nema ni njega.
Izbor nam je sacuvaj boze, kao da otpatci nakupljeni ne prodati dolaze.
OCz
Gigabyte P55A-UD6
LG 32LK450
Nemam
Imam
Windows 8 Pro x64
Ovaj XtraFlo je izgleda zamena starom SickleFlow-u. Vise mi se na oko dopada, a kakav je - ne znam.
A sto se tice AP-15, pazi, vrti se na max 1740-1750RPM i tu nije tih. Cuje se fino protok vazduha, mada za taj RPM i nije toliko bucan koliko jeste dosta drugih ventova.
AP-14 (1450RPM, u praksi cenim da je to 1350-1400RPM, i naravno gledam iz aspekta AP-15 kada se nalazi na tom RPM) je vec za vecinu ljudi solidno tiho a vent pravi dobar protok vazduha. Ko nema fan kontroler, svakako bi mu preporucio da ne uzme AP-15 vec AP-14, ili ako zeli nesto dosta tiho, za vecinu ljudi i "necujno" onda je AP-13 sigurica. Mada na tih ~1100RPM nece biti bas neki extra performer, ali uz dobar hladnjak ili radijator to je dovoljna brzina i za sasvim dobar OC.
Inace da, motor bi se moglo reci da mu se ni ne cuje, a ako se i cuje na vecim obrtajima to biva progutano od strane huka vazduha pa je nemoguce zasigurno reci.
U vezi sleeve-a, sigurno cu ceo kabl presvuci do motora. Kada se zategne sleeve staje to bez problema u njegov kanal od rama do motora.
P.S meni je ovaj fan u kucistu (opet, kao i velika vecina drugih) zaista necujan tek na izmedju 900-1000RPM. Cisto da se razumemo koji je moj kriterijum, kada kazem necujno mislim na to da kada padne mrak i vlada mrtva tisina, ja jedva primetim razliku kada je masina ugasena, a kada je upaljena. Menjao sam fan na napajanju za tisi, modovao sam BIOS karte da bi mogao da spustim fan ispod 40% (drzim ga na 25% tj. 930RPM u idle, fabricki je 1450RPM). A pricamo o GTX570 za koju su skoro svi rekli da je jako, jako tiha kartica.
Iv4n
Asus P8P67
Dell U2713HM IPS
Samsung 840Evo 250GB
Seasonic X-750
SBB 70Mbit
Win 7 SP1 Ultimate - X64
@OCz: Imas farbare koje ce ti elektronski 'skenirati' noctua boje i umesati boju i cak napuniti aerosol konzervu tim bojama da bi mogao da ofarbas!! :) Ne bi trebalo da bude nesto puno skuplje od obicne sprej-konzerve. Raspitaj se ko to radi. :P
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Cekaj jel se cuje zvuk ventilatora kao CORSAIR ventilatori sto zuje???
Ja nisam cuo to bas. Slusaj na video klipovima.
8 komada
Oni za Hydro seriju inace onaj mali je tih sto se dobije sa 650D.
Vidi ga na push-pull
http://youtu.be/wXk0pfzC3Co
Znas sta je to u zatvorenom kucistu, nista.
Jbg ne moze kom da bude kao stolica tih. Da ga gledas da ne znas da li radi a zelis svuda 60fps.
Moze za 3000e.
To sto ti rade sproije to je na Fan kontroleru se desava ljudima da tako radi inace radi na 1800-1850 nekima i 1870RPM.
Na molexu mora da radi izmedju 1800-1850 ne smeju da ukradu 100rpm nikako. Nema govora o tome. Prikljuci na plocu pa ocitaj 1800-18xx garant. Svi dodaju po 40-50-60rpm na brzinu, kao i moji CORSAIR sa resistorom su 1600rpm po specifikacijama a meni idu i do 1680RPM. Ne smeju da ispod specifikaciju urade.
Lamptron kontroler isto nekim ljudima smanji na najmanje 1750.
Ja bi voleo da imam onaj od 2150RPM ali nema ga. Neko stavi one na 1600RPM i uziva na kontroleru.
Ali ako meris granu od 12V i ona ti je 12.28V ne sme da ti tu daje ispod specifikacije moze samo da ga ubrza.
Ja cu na full speed. Pogotovo sto za push-pull je veoma bitna brzina do + - 50RPM toleracncije.
Zamisli da ti jedan radi na 1700 a drugi na 1800 ili jedan na 1850 a drugi na 1750RPM. Ne smeju to da urade sem na kontrolerima.
Ali ako stavis na CPU Fan mora da ocita 1800-1900RPM nebitno koji broj. Zna proizvodjac da se koristi za push-pull cesto gde je jednakost presudna kao na CORSAIR fanovima. Ista dva. A ovo je Nidec koji je malo ispod Sanyo Denki.
OCz
Gigabyte P55A-UD6
LG 32LK450
Nemam
Imam
Windows 8 Pro x64
Pojma nemam sta zelis da kazes u svojim postovima, niti mi je bitno. Samo da izdvojim ova dva dela;
Moj je takav. U idle tih kao stolica, u igrama kada mi vise ni nije bitno malcice glasniji (samo se fan na karti ubrza).
Specifikacije ventilatora (99% njih) su takve da pored stoji 10% +/-
10% of 1850 je 185. Znaci za ocekivati je da moze da radi od 1665RPM do 2035RPM. Pa kako kome zapadne, oba moja ne idu preko 1750/80RPM.
Hm, to je fino. Nije mi palo na pamet ..
Probacu prvo da nadjem sprej krem boje ili nesto sto slicnije tome, pa ako bas ne budem imao srece tvoj predlog stupa na scenu :)
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
Evo su ovi kao koje nema Evropa i USA.
http://i.imgur.com/Hl9af.jpg
1700/2150/2450 ili 2650 nisam siguran
10% odstupanje na molexu za Fan??? Nikada nisam video to.
Ni na jednom vise od 50 i to brzi obicno.
Znaci onaj od 500RPM moze da se jedva okrece da vidis propelere.
Na 400-450rpm da radi.
Ma nek mi rade na 1800 na ploci i OK.
vlada.j011
HD 5870 2GB
Samsung P2450H
Seasonic X-750
LG GH22NS50
Logitech G510/G700
Telekom ADSL
