Rockstar problem
tomicc
Ryzen 5 3600 Stock Cooler
Gigabyte B550M DS3H
Kingston Hyperx Fury RGB 2x32GB DDR4 3200Mhz
RX 580 Sapphire Nitro+ 4gb
Dell S2721DGFA 2K 165hz
WD Blue 4TB
MS Armor V700
Cooler Master 700w
Zna li neko kako da fixam ovo? Kad zelim da udjem u rockstar launcher iskace mi error, na yt ne mogu da nadjem fix sve sam probao ali nece?
48292
Reinstall ?
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
Probao i nece, iskoci sam ovaj errori i to je to
Nisi kamena zvezda onda jbg :)
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
kako mislis nisam? ja sam skinuo taj launcher ali kad zelim da ga pokrenem iskace error
Kako si ga skinuo?
Za šta si ga skinuo?
Imaš li koju njihovu igru instaliranu?
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
@PORSCHE Skinuo sam ga sa sajta od rockstara, skinuo sam da bih kupio gtav, nemam nijednu skinutu igru njihovu, cak nemam ni acc
Samsung 870 EVO 500 GB sata ssd + Seagate 5 TB sata hdd + Cusu 512 GB 3500q nvme
launcher error
"Check your “launcher.log” file located in “My Documents\Rockstar Games\GTAV” for errors or indicators of the cause. "
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
launcher error
imam samo prelaucnher.log zato sto nemam ni acc samo imam key za rockstar kupljen..
Ovo pise u prelauncher
[2022-11-19 13:57:13.383] [DISPLAY] LauncherPatcher version: 1.0.0.14
[2022-11-19 13:57:13.383] [DISPLAY] Launcher version: 1.0.0.14
[2022-11-19 13:57:13.383] [DISPLAY] Retrieving Launcher manifest: "https://gamedownloads.rockstargames.com/public/prelauncher.ini"
[2022-11-19 13:57:13.388] [DISPLAY] Retrieving minimum supported versions.
[2022-11-19 13:57:13.578] [DISPLAY] Minimum LauncherPatcher version: 1.0.0.12
[2022-11-19 13:57:13.626] [DISPLAY] Running Launcher from "C:\Launcher\Launcher.exe"
[2022-11-19 13:57:15.092] [DISPLAY] LauncherPatcher version: 1.0.0.14
[2022-11-19 13:57:15.092] [DISPLAY] Launcher version: 1.0.0.14
[2022-11-19 13:57:15.092] [DISPLAY] Launcher exited with code: -1073741819
[2022-11-19 13:57:15.092] [ ERROR ] Failed to run Launcher
[2022-11-19 13:57:15.130] [ ERROR ] Displaying Error titled: Error
[2022-11-19 13:57:15.130] [ ERROR ] The Rockstar Games Launcher failed to initialize!
Please visit Rockstar Games Customer Support for more information.
[2022-11-19 13:57:16.375] [DISPLAY] Shutting down.
pretpostavljam da si probao launch as administrator?
VirusX
Ryzen 5 1600X & CM ML120 Lite
Asus ROG Strix B350-F
Radeon RX 570 4GB XFX
Samsung 24"
Samsung EVO 860 500GB
AW + 3x AF P12 PWM
Corsair 650 80+ Bronze
Redragon
Imam
Windows 10 & Brave
Ovako se pišu try/catch funkcije u trećem razredu srenje škole.
Njihovi zaposleni nisu izgleda mrdnuli mnogo odatle. Ovaj log je beskoristan.
Skini Bulc Crap Uninstaller i obriši laucher skroz.
Restartuj komp, skini ga ponovo i instaliraj.
EDIT
Odradi i windows update pre nego što opet instaliraš to smeće
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
@VirusX Probacu sad, nadam se da cu fixati posle 4 dana..
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
EDIT
ma kakvi ne radi ni to jedino mi ostaje novi windows sto cu i uraditi
VirusX
Samsung 24"
AW + 3x AF P12 PWM
Redragon
Imam
Windows 10 & Brave
Probaj i to, ne znam.
Ili samo sačekaj neku nedelju, dok ne izbace update za launcher, verovatno nisi jedini kome se ovo dešava
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
ma uradio sam windows opet iskace isto ne znam da li je do mene ili do njih
VirusX
Samsung 24"
AW + 3x AF P12 PWM
Redragon
Imam
Windows 10 & Brave
Posalji im log fajl i pitaj za pomoc.
I kupuj igre na Steam-u :)
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
nemanja81
Jesi li uspeo da resis problem?
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
tomicc
Gigabyte B550M DS3H
WD Blue 4TB
MS Armor V700
Cooler Master 700w
Nema na cemu ;)
