c-p-r
Ne znam da i je do mene, do verzije ofisa u smislu da ne poseduje tu mogucnost, da sama verzija ima nekih nedostataka ili sta je vec ali ne mogu da podesim boju senke na slovima, ni to a kamoli jos neke parametre vezane za senku.
Siguran sam da je predjasnji ofis ili onaj pre njega (dakle 2003 i 2007) imao vise podesavanja za senke.
Naime jedino sto funkcionise trenutno je "Text Shadow" opcija pored bolda i italika.
Zar nema nesto vise?
Format-TextEffect i Shadow ne daje rezultate.
Edit:
Nadjoh ensto posle dosta bezuspesnih pokusaja, mada opet ne resava problem do kraja, nepotrebno su ovde nesto iskomplikovali, nemoguce da ima manje opcija nego ranije.
Edit:
PowerPoint 2010 Drop Shadow Compatability
When importing earlier versions of a file into PowerPoint, whether or not you experience issues with drop shadows depends on how you apply the shadow.
If you apply the shadow in 2003 using the text shadow options then you should not experience any issues when playing the file in 2010.
The problem seems to occur after using the apply object shadow tool in 2003:
To rectify the problem in 2010 you must remove the non-compatible shadows and reapply them using 2010 shadow effects. If PowerPoint will not let you edit the shadow then you are probably running the slides in compatibility mode (PowerPoint 97 – 2003 presentation). This will limit 2010 functionality to that of a 2003 version. Remove compatibility mode by going to ‘save as’ and selecting pptx file type, which will be named ‘PowerPoint Presentation’.
You should then be free to edit, remove, and reapply 2010 shadow options and animations via the PowerPoint 2010 toolbar.
Has this solved the probelm? Have you discovered more compatability issues within PowerPoint 2010, or encountered other PowerPoint difficulties in general? Leave a comment below with any queries you may have, and we’ll get m62′s design team on the case!
Edit 2: Dakle samo prebaciti u PPTX, odnosno Power Point Presentation i sve ce se opcije pojaviti. Ne znam da li je ovo kod mene po defu ovako ili... ali mozda je neko nesto dzarao...for precision shadow effects in 2010, forget using the ‘S’ shadow toggle button in the text formatting area of the Home tab. Instead, highlight the text you’re playing with, right-click and select Format Text Effects. In the formatting window, click Shadow, and you’ll be able to play around with the colour, Transparency, Size, Blur, Angle, and Distance of the shadow, or choose from a big menu of preset effects.
