Hitachi GST reveals 7mm 2.5" hard drive for slimmer than slim notebooks
It had to happen at some point. The standard 9.5mm height hard drive has been around for years, and even in super-thin notebooks of today, that drive has managed to fit. Snugly, of course, but still fit. But with new notebook concepts pushing the boundaries of thickness, there had to come a hard drive maker with a plan for slimming things down. Hitachi GST has done just that with their Z-Series Family, which is described as the "industry's highest capacity and fastest 7mm ultra-thin and light hard drives."
These new 7mm drives are meant for the slimmest of machines, and we probably won't see them used across the board for a few more years still. Both the Travelstar and CinemaStar lines are getting the new, slimmer model, with capacities offered as high as 320GB. It also spins at 7200rpm, so there's a speed advantage as well. The company is hoping that these drives will help lead the shift from 9.5mm 2.5" drives to 7mm 2.5" drives, and a great many tablets could also take advantage.
While the size is still somewhat unique, the ports and connectors are not; standard interfaces will have no problem fitting in with the new HDD. No prices are mentioned yet, but volume shipments are expected by July. Expect your next thin-and-light to be thinner than ever if it's using one of these. Now, if only we could figure out how to slim those optical drives down as well...
Izvor: HotHardware.com
