Explore&Burn (freeware)
CD/DVD burning from the right-click menu
Explore&Burn is an easy to use CD/DVD burning utility that integrates with the Windows Explorer right-click menu. Just select the files, folders or an ISO image file that you want to burn, choose the `Burn to disc...` option from the context menu and follow the two step wizard to create your CD or DVD. Explore&Burn supports single-session and multi-session discs with ISO-9660, Joliet and UDF file systems and a wide variety of disc types.
http://exploreburn.com/
