CNPS9900 Max CPU cooler - prelepo!
Going back to the original design, Zalman launched the CNPS9900 Max CPU cooler. The cooler has the round butterfly design that many so appreciate. it gow a bit of extra attention though as a high performance composite heatpipe is now applied.
Zalman claims the cooler can deal with an impressive 280W Q Max. The cooler comes with a Quiet 135mm FDB (Fluid Dynamic Bearing) LED Fan which is PWM Fan Speed Controlled.
The cooler itself has nicely Black-Pearl Nickel Plating making it look really nice. Along with the cooler you'll receive some Super Thermal Grease ZM-STG2 Included. Have a peek.
Zalman CNPS9900
SuperStarr
ASUS VW222U
1x Maxtor, 3x WD, 1x Hitachi
ZM850-HP
LiteOn always & forever :P
Telekom ADSL 1Mbps
2x Doggy Dog ?
jes' lep, ali pitanje koliko je efikasan :p
e sad koliko je to istina...
Heeeee, neki tvrde da je prosecna plata u Srbiji 350 evra pa svi znamo da to nije istina ;) da ne budem prost pa da kazem neku drugu izreku( I na tarabi pise p**** pa jos niko nije j*** :d )
Sve jedno treba da bude lep a ne dobar :)
JBL
Mdpc 036
Super je, samo je ova slika sa sajta malo pod efektom pa deluje jos bolje :D
nije to isti kuler, to je obican 9900NT (ima manji vent i nije black-pearl nickel plated)
JBL
Mdpc 036
Ups sorry :D
oprosteno ti je :D
ovaj put :d
