Antec True Power 1200 OC Edition
12x 6pin pcie connectors (via 6 REAL Lines) at 2200UFx6 - 13,200UF at connector end - All the solid caps on MB/VGA has only 300+UF max per cap for 16v rated due to only non-solid caps can go high capacitance.
so 4 x 285 classifieds or 4 x 5870s (soldering on an addtional connector per card if you are boosting your input)
or 6x 6 pin pcie connectors + 6x 8pin pcie connectors (via 6 REAL Lines)
2 x 8 pin cpu 2200UFx2 @ connector end
lots of molex and satas.
suba
Asus Z170-A
MSI GTX 1060 Gaming X 6 GB
EVGA SuperNOVA 850 G2
Ikom 100/3 :: Asus RT-AC55U
Windows 10 Pro x64
Dell XPS 15 L502x
Jaoooooo jaoooo koje je ovo zlo od napajanja !!!
ASUS TUF B850M-E WiFi
32GB Corsair DDR5 6000 CL30
Lian Li 217
Mogli su neki 50 ili 60mm fan da stave, previše je 80mm...
JBL
Mdpc 036
Pffff znaci brooka matori :) Jedino steta sto nije full modularno,al presao bi preko toga :p
PC & C turbocool sa cable mendzmentom ? :)
darkado
Gigabyte MA770-UD3 (rev 2.0)
Saphire Radeon 5750 1GB
Samsung T220
WD 320 AAKS + WD 500 ABYS
Integrusha
Cooler Master Elite 332
Pioneer 215
2Mb
Win7 RTM 64-bit
kakva grdosija
Oki
Nije hejt ali ja bih bolje cifre napisao od onoga gore..izgleda kao da ga je dete od 5 godina pravilo u kolazhu...
silovito nema shta..samo pitam se za koju svrhu ??
Shiki
4GB DDR3 1066MHz
LG LC55 42"
Logitech Z5500
Cable 8096/384
Snow Leopard 10.6.6 :)
Macbook White Unibody
'ebe ga korishcenje aparata :d , ja sa mobilnim bolje slicke pravim :d
Inace 12x6 pin ... :balavim:
Hector Ruiz
Intel i5 4670K@ Megahalem
ASUS Maximus VI Hero
Intel HD4600
Samsung P2470H
microlab Solo6C
Corsair 800D
Seasonic X-850 SS-850KM
Kablovska
Windows 8.1 64bit
J....o ih 80mm ventilator :mad: , mogli su da mu promene dizajn.
CAR
Gigabyte EX58-UD5
Samsung SyncMaster T220
Cooler Master Cosmos S
Samsung SH-S203B
aDSL 1024/128
Al' je grdnoooooo...
mipko
I7 920 D0 @ 3.6GHz
EVGA E760
Lenovo L220X
Asus Xonar Essence STX
Lian Li 2120b
Antec HCP 1200
Logitech Illuminated
Windows 2008R2
ovo je primer kvaliteta koji izgleda kao najgori kitch...
CAR
Gigabyte EX58-UD5
Samsung SH-S203B
aDSL 1024/128
Bravo majstore, excelent point!
Pogledajte sta moze ovo napajanje :eek::eek::eek::balavim::balavim::) vredi svaki evro :cool::):)
sick!
odakle im 2x24 atx konektora :)
kizzam
I7 920 D0 (24/7 4.4Ghz HT-on)HWLabs GTX480 x 3,Apogee XT,D5 pumpa,T-line
ASUS Rampage II Extreme
Patriot Viper 3x2GB 1600Mhz
XFX GTX 280(648/1224/1350)
Viewsonic VX922
Seagate 2x500Gb
Creative SupremeFX X-Fi
Corsair Obsidian 800D
Corsair HX 1000W
Plextor 810SA / Samsung SH-S223B
Microsoft
Vista & 7
Ovo vozi dve konfiguracije pri Oc-u stvarno odlicno napajanje ali nikad ih nisam primecivao jer su stvarno ruzna.:eek:
1600W ej bre :D
kizzam
Viewsonic VX922
Seagate 2x500Gb
Corsair HX 1000W
Microsoft
Vista & 7
Moze onda i TA pec da prikacim !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:rotf:
Ako ne vidite onaj plavi Corsair u pozadini, onda je i jasno kako vuce 1600W
A odatle i 2x24pin :d
koliko vidim od corsa je uzet samo 24pin
sve ostalo je nakaceno na antec
tu su hteli da pokazu da natec gura 4 295GTX i to dual pcb
Hector Ruiz
Intel HD4600
Samsung P2470H
microlab Solo6C
Corsair 800D
Kablovska
Windows 8.1 64bit
CooLa
I didn't ask for this
Mainframe
AMD ThreadRipper 2920X
Asus ROG Zenith Extreme
MSI RTX 2080Ti
3x Acer Predator 27"
Integrale
Phanteks Evolv X
Corsair HX1200i
LOL
Orion 1Gbit
Alienware R13 R3
80mm Vent nije problem. Ja imam PC&C 750W (A.k.a OCz Silencer Quad 750W) i ne cuje se... Vrlo je fino i tiho... A guralo je i jace konfe nego ovu iz potpisa ;)!
Unfortunately, something else was also outstanding. And unbearable. The fan. It got loud by test three. I don't mean just noticeable either - I mean "howling its little face off" loud. It easily drowned out all the other fans in the room, including the 120 VAC 120mm dual high speed fans in the SunMoon, including the three 12V high speed fans in the auxiliary loaders, including all the fans in the office computer. It was ear piercing.
da 80mm vent :)
ELPR1NC1PAL
CORSAIR
Ci7 975 PreProduction @4,xxGHz Engineer Sample - Corsair H50
GigaByte GA-X58A-UD9
Corsair DDR3 Dominator GT 12GB by 1866 MHz CL8
4x EVGA GeForce GTX 480SC QSLI Mode LuKü
2x Eizo SX2461WH-BK 24" HDMI / FULL HD 1080P
2x WD Velociraptor 600GB SATA600 RAID Systemdisc + 2x WD Caviar Black 1TB SATA600 Dataspace
Enermax Revolution 1250 Watt
LG BluRay Writer (12x)
G9 + G19 by Logitech
2x 100 MBit Cable by KD
Windows Seven 64 Bit Ultimate Edition
KillerN1C Xeno & Beyer Dynamic Manufacture 300 MMX Headset
