Thermaltake Water 2.0 Extreme
deluxe
Acer Aspire V3-771G
AUO HD+ 17.3" 1600x900 LED
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Telemark 2048 KB / 256 KB
Bluetooth 4.0
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
Jedno je da podrzava a drugo da ima 63mm prostora za vodeno hladjenje da se montira.. Mene to interesuje.
Product sheet sa oficijalnog sajta je čudo! :D
http://www.fractal-design.com/downloads/ArcMini_product_sheet.pdf
Da ti pomognem:
*The component support in the case when using radiator in top is depending on the thickness of the radiator.
See info below. When having a 2x120mm radiator mounted in top, you cannot use the rear 120mm fan slot at
the same time.
- Up to 40mm radiator thickness: Support for most water CPU coolers and larger memory modules.
- Up to 50mm radiator thickness: Support for most water CPU coolers and standard memory modules with a
height of max 35mm
- Up to 70mm radiator thickness: Support for only certain water CPU coolers, depending on the water inlet
and outlet. Supports standard memory modules with a height of max 35mm
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
Ja da sam znao gde je pdf, download bih ga. ;) nema potrebe za takvim ponasanjem (ismejavanjem) ipak si ti moderator, trebalo bi da vise vodis racuna o izboru reci i kako ces nekome da se obratis. c.c.c.c. PS: Primera radi, Xigmatek Midgard II podrzava i 280mm RAD ali ima 50mm prostora, nadam se da sad vidis razliku u 'podrzava' i 'ima prostora', zato sam te i pitao ono. :)
Kakvim ponašanjem? Ne smem se dobro nasmejati ako sam moderator? :D Ako te "kritikujem" to je problem, ako se smejem to je problem. Čoveke tebe nije lako zadovoljiti. :D
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
Nije problem da se nasmejes, problem je sto ismejavas. Sram te bilo a moderator si. Nije glupo kada neko ne zna nesto i pita, glupo je kada se tom koji je pitao neko smeje jer smatra da je popio svu pamet sveta inace to je veoma nekulturno. :)
Ajde deluxe opusti se, previše si ti napet, nema potrebe za takvim reakcijama. :) Nisam ja pametan, samo znam koristiti internet. ;)
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
nema potrebe ni da me ismejavas ako ja nesto nisam znao. :) mogao si samo da okacis link za pdf bez onog smejanja a ja bih ti se kulturno zahvalio. :)
@deluxe
Druze, stvarno si previse napet. Stekao sam utisak da ti od svake situacije uspesh da napravish da je neko protiv tebe. Opusteno brate mili, ovo je forum, bitna je informacije. Sto se mene tiche, slobodno me svaki put oterajte u materinu, ako je u okviru posta i informacija koja pomaze. Konkretno u ovom slucaju, Steamroller ti nije rekao nista ruzno, stvarno ne vidim gde je sada problem?!
Dobio si sve informacije koje su te zanimale, a stvarno nije ni obavezno da se zahvaljujesh... Ovo je forum, pomazemo jedni drugima, i u startu se ocekuje da se to bezrezervno i bez ikakve dobiti, zahvalnica i sl radi...
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
Dule, da te pitam. Jel u redu da mi se forumski moderator smeje ako sam pitao da li ima 63mm prostora u vrhu kucista za montiranje vodenog hladjenja? Sta je tu smesno? Inace nisam napet samo sam direktan, ne okolisem pa to tumacite kao da sam napet. Boze zdravlja pa da nekad popijemo neku, da vidite kakav sam kao covek. :wave: :ziveli:
Mi tumačimo da si napet, a ti tumačiš da se ja smejem. Odakle insinuacija toga da se ja vajam na podu i smejem se ako napišem ":D"?
Pa gle, ja mislim da je problem u tome sto ti mislish da se on tebi smeje... Zamisli sada mene kako ti kazem sledece: Deluxe, previshe si napet! i stavim smajli tj ovo :). Pa jel to znachi da se ja tebi rugam? Ili mozda znachi i da ti dajem osmeh da shvatish da je sve ok i da nemam nista protiv tebe...
Opusteno ljudi, ovo je samo forum, chemu nervoza koji moj...
P.S. Da ti se rugao veruj mi na rech da prvo od mene packu dobio ;) Ako bi josh sebi dao za pravo da se ljuti i da ga pukne sujeta, cao-zdravo, ja za takve nemam vremena. Opusteno bre :) I upamtite, nije bitno koje je e-piša veća, bitno je da se ne piša van WC šolje :D
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
Deluxe, pa ti si napet? :D
neSSa
i7 5820k + EKWB
MSI X99 Mpower
16gb HyperX Predator 2666Mhz
SLI - Asus GTX 770 dc2 + EKWB
Dell 27" IPS
"MasterX5" project
Cooler Master V1000
ASUS external
A4Tech - mouse and keyboard
Pa cemu sve ovo ljudi i to u ovako lepoj temi, da napomenem da je uredjaj inace super, takodje i ima novog vlasnika , i opet taj isti :D
deluxe
Acer Aspire V3-771G
Aspire V3-771G
Acer 6-cell 48Wh
Pioneer DVD-RW
Gigabyte GM-M6800
Bluetooth 4.0
