NZXT Performance Power 800W PSU
activated1
a1-PC
ASUS M5A99X EVO
4x4GB Kingston HyperX Genesis
BenQ 2450
Corsair Obsidian 750D
Corsair RM1000i
Telekom VDSL 20Mbps/4Mbps
Features:
* SLI-ready Certified Power Supply
* Complying with Intel ATX / BTX Standard
* Gold-Coated Connectors
* Output Over / Under / Short / Overload Protection
* 78% Efficiency at load
* Smooth black matte finish
* Industry Standard ATX V2.91
* Low Noise 80mm and 120mm Fan
* Four +12V Rails
* PCI-E 6/8pin, SATA, EPS12V Ready
Kod:
Specifications:
Brand : NZXT
Series : NZXT Performance Power seriesModel : PP800
Type: Complies with ATX 12V 2.2V
Maximum Power: 800W
Fans: 120mm Fan @ 1900 RPM
DIMENSION: 140 X 140 X 25 mm
AIR FLOW: 82 CFM
TEMP. AUTO CONTROL
Main Connector: 20 + 4 Pin2
Dual +12V: QUAD 12V RAIL-DESIGN
PCI-E Connector: 2 x 6 Pin, 2x 6+2Pin Cross Fire Ready.
SLI Support: Yes
Efficiency: Up to 85 %
Power Good Signal: 100 < 500 ms
Hold-up Time: 16ms min.
Over Voltage Protection: Yes
Overload Protection: Yes
MTBF: >100,000 hours
Review
to je ono sto ima San Ace 120mm vent?
ASUS TUF B850M-E WiFi
32GB Corsair DDR5 6000 CL30
Lian Li 217
Znači, 120mm fan dimenzija 140x140x25 :D :D :D
mozda je kao ovo samo slabije...
svejedno 120 ili 140mm, na 1900rpm-a je izuzetno nečujno..:D:D:D
bas htedoh da napisem :D Deluje onako, solidno, mada ja ne bi probijao led, a nesto sumnjam u tih 800W
