asus proart b550
g.skill trident z neo 32gb
asus vg27aql1a
optical cable
The monitor specialist Eizo has incorporated inches with the "DuraVision FDH3601" a new display with the diagonal of 92 rich in its range. The 36.4-inch monitor offers a resolution of 4096 x 2160 pixels, and thus a quadruple full-HD resolution. Other key data of the device is an LED-backlit display and the "Digital Uniformity" equalizer is a color precision with 16-bit Look-Up Table and possible up to 10-bit color rendering. Through the LEDs installed according to manufacturer's brightness boost of 30 cd / m² to 700 cd / m² possible and therefore, each user should easily find the perfect brightness for himself. The viewing angles are in the data sheet at 176 degrees from horizontal and vertical direction, and the contrast is given as 1000:1.
To transfer the image data to the device can be both two display ports, and two DVI inputs are available. The FDH3601 processed internally two image halves (left and right) separately and it will automatically connect to a picture. The separate supply of left and right side of the screen behaves as if there would be two monitors without a disturbing part in the middle. When power consumption is EIZO maximum value of 350 watts in off mode and the monitor will need a maximum of 6 watts.
hardwareluxx.de
The DuraVision FDH3601 EIZO is commercially available as of 28.11.2011 and the suggested retail price is 25,000 €.
hardwareluxx.de
