Tutoral Samsung Galaxy Ace Duos GT S6802A - DROID ROM v2.0 FOR ACE DUOS [RELEASED}
bogovinska
Naredne postupke radite na sopstvenu odgovornost, niti je, niti PCAXE ne moze snositi odgovornost ukoliko na neki od navedenih nacina dovedete telefon u tzv.brick-ovano stanje.
Generalno, kod mene su ovi postupci bili uspesni u 100% slucajeva ali to ne znaci da ce i kod vas sve biti 100% tako.
1. CUSTOMDROID ROM ( A-DROID ROM V 1.0) .zip http://www.mediafire.com/?05nbcgagd67wj3j
2. A-DROID ROM 2.0.zip
HOW TO INSTALL ROM :- http://www.mediafire.com/?cdnjjjazpz79fm1
3.iDuos Kernel - http://www18.zippyshare.com/v/50501362/file.html
4.CWM FOR s6802 - http://www.mediafire.com/?e2fqgs4qf8jcbwf
1. Go in RECOVERY Mode By Pressing ( VOLUME UP + HOME + POWER BUTTON )
2. Wipe Data And Cache ==> Then Select CWM RECOVERY (assuming you already placed CWM in memory)
3. Go to Mount ==> unmount system,data,cache ==> Format system,data,cache ==> Mount system,data,cache
4 Come Back and select install from zip
5 Select My A-DROID ROM v2.0.ZIP [assuming you already placed it to memory card or internal memory]
6. Install it....! Reboot ! press and hold power button to reboot !
7. Enjoy and Post Here about your experience..
HOW TO INSTALL KERNEL :-
First install Drivers By Installing Kies . . . !
1. Download Kernel And Odin
2. Go to Download Mode By Pressing ( VOLUME DOWN + HOME + POWER BUTTON ) nd then press Volume UP
3. Connect phone to pc through data cable
4. Run Odin ==> Select Kernel FIle as PDA and press Start..
5 It will automatically Reboot
6. Done
ROM Features :-
Based On Latest Stock Firmware DDLI1
Deodexed And ZIpAlgined
14 toggles by lidroid
BEATS AUDIO
DSP Manager
Special Droid RAZR Bootanimation with Sound !
XPERIA S HOMESCREEN !
XPERIA S WIDGETS
ClockWidgets
OnOffTools
Brightness
PhotoWidget
WeatherWidget
1% Battery Mod
I-PHONE Lock Unlock Sounds
InBuilt CALL RECORDER
XPERIA FONTS
Replaced some system apps with better ones!
- Tape-a-talk voice recorder [High quality record at cd quality instead of samsung's crap recorder]
- QuickPic instead of Gallery3D [Big battery drain in gallery3d!]
- Added AppWidgetPicker, so the widgets are better categorized [Thanks to boombuler]
PreRooted
Busybox Installed
Fugutweaks
Good battery life!
Bloatwares Removed
A-DROID THEME 2.0
-> Full Framwork Modded
-> Bootanimation Changed,
-> Modded SMS app - ICS Themed !
-> Contact app modded
-> Settings Modded
-> MUSIC APP MODDED - ICS And Beats THEMED
-> Dialer Modded - ICS THEMED
-> Shrinked Quck and Carrier Bar to Get some more space for Notifications
3 LAUNCHERS TO CHOOSE FROM :-
XPERIA S HOME
HOLO LAUNCHER
LAUNCHER PRO
SEVERAL APPS ADDED :-
Real Calculator
Explorer
Call Recorder
QuickPic
Adfree
Tape-a-Talk
Notification Sounds Changed
Lot of Build.Prop Tweaks
Features
✔ Increase touchscreen sensitivity
✔ Less RAM usage through zipalign. | World first smart zipaligning
✔ Reduced /dbdata, /data, /sdcard usage of *.db files and faster database access. | World first smart sqlite optimizing
✔ Faster disk access through remount script (noatime, disabled barrier etc) | World first smart remounting
✔ Better network throughput from TCP tweaks and 3G tweaks
✔ Tons of prop tweaks
✔ Overall Better Performance and Battery Life
✔ Less lags through LMK Tweak and Various VM Tweaks
✔ Faster SDCARD Read/Write Speed
zookarma
i5 750 + Megahalem
Asus p7p55d
2x2 Mushkin + 1x4
Sapphire 6950
Samsung T240
C300 X64 + 5xhdd
Creative Xfi Elite
Chieftec LBX
TT 650 W
PIoneer 212
G500 + G15 v2
Win 7 x64, Chrome
Da li kernel moze flash preko recoveryja ?
zookarma
i5 750 + Megahalem
Asus p7p55d
2x2 Mushkin + 1x4
Sapphire 6950
Samsung T240
C300 X64 + 5xhdd
Creative Xfi Elite
Chieftec LBX
TT 650 W
PIoneer 212
G500 + G15 v2
Win 7 x64, Chrome
Hvala svakako :) Komsija ima soff pa cu mu predloziti :)
Diabolique
E5200
P5Q
2x2GB
DIY Projektor
10001FALS, 10EACS, 10EADS
Audigy@Z5500
Generic
CM 450 RP
Pioneer 215D
MS Natural 4000, MX1100R
IKOM 2Mb
Win XP
Hvala za uputstvo. Odlično odrađeno.
zookarma
i5 750 + Megahalem
Asus p7p55d
2x2 Mushkin + 1x4
Sapphire 6950
Samsung T240
C300 X64 + 5xhdd
Creative Xfi Elite
Chieftec LBX
TT 650 W
PIoneer 212
G500 + G15 v2
Win 7 x64, Chrome
