Kupio sam monitor od 144hz a mogu da ga koristim samo u 120hz, sta da radim?
Aleksandar V
Trazim vec nekoliko sati na internetu resenje ali se ne snalazim bas najbolje, monitor od 144hz mogu da koristim u najvise 120hz. Oznaka monitora je DELL S2421HGF, kupio sam ga u Srbiji i svugde pise da je 144hz, kako na sajtu tako i na kutiji samog monitora. Nadam se da ce mi neko pomoci oko ovoga. Hvala unapred :)
40814
daka
Intel i5 11400 + Artic Freezer 34 eSports
MSI b560m pro vdh wifi
Patriot Viper 4 16GB DDR4 3200MHz CL16
Gigabyte RX 6600 XT oc pro
AOC 24G2U/BK IPS 144Hz
Kingston 1TB A2000 M.2
Sharkoon WPM 600W modulare
MX518
Pa hdmi ti izbacuje 120hz, uzmi display port i imaces 144 xD
Ryzen 5 5600
AsRock AB350 Pro4
SBB Cable 600/60 SBB
Xaomi 15T 12/512GB
Ocigledno je sam HDMI limitiran na 120Hz * HDMI 1.4*, a to nije do kabla.
Kao sto ti clan rece ranije, moraces na Display Port.
Zasto to rade nikome nije jasno ali eto, desava se.
Retko koji monitor ima HDMI koji gura 144Hz u 1080p.
Evo i dokaz:
Nowadays, most monitors, TVs, and graphics cards feature at least an HDMI 1.4 port which is enough for 144Hz at 1080p, 75Hz at 1440p, and 30Hz at 4K.
However, keep in mind that some monitors have limited bandwidth over HDMI 1.4 making it max out at 120Hz or even at 60Hz in some cases (mostly G-SYNC and older monitors).
In fact, most 144Hz monitors are limited to 120Hz over HDMI 1.4, but some monitor manufacturers will utilize custom timing parameters, pixel rates, etc to use the full potential of the HDMI 1.4 bandwidth thus getting 144Hz at 1080p.
So, make sure the exact monitor you’re looking at supports 144Hz or at least 120Hz over its HDMI 1.4 port – or just look for a 144Hz display with HDMI 2.0.
Nvidiaja ima opciju custom resolution gde mozes da podesis sve zivo.
mozda neces imati 144 cak i sa dportom iz prve nego moras rucno da podesis.
40815
Nema razloga da nema ako je fabrički deklarisan na toliko...
To je onda oc monitora,nema veze sa ovim.
Ako monitor ima dvi-d moze i preko njega.
Ryzen 5 5600
AsRock AB350 Pro4
Xaomi 15T 12/512GB
Ima samo
Ports
  • 2 x HDMI
  • DisplayPort (DisplayPort 1.2 mode)
  • Audio line-out
Tako da ce morati DP, posto HDMI nece da mu baca 144Hz.
Al neka proba sve zivo :)
Ja imam 75 herca monitor, ne postoji opcija i uopste mi ne nudi 75 herca po defaultu dok sam ne podesim.
(poslednji drajveri naravno ista stvar i sa HDMI i sa Displayport kablovima.
Pa kažem,to je klasičan oc monitora.Trebalo bi da proizvodjač pošalje kabl u paketu sa monitorom koji podržava deklarisane vrednosti "iz kutije" tako reći.Ali vidimo da nije redak slučaj da ne dolazi.
Stavljao sam i ja 75 hz manuealno,ali monitor je deklarisan na 60.
Ako tako monitor ne moze da da 144hz,nego moraš ručnu to je 120hz osvežavanje.
Naravno postoji takozvani oc fabrički kod pojedinih modela monitora gde jasno piše.
Ako bocne odgovarajuci kabal i opet ima samo 120 herca, nista strasno sredi se. Meni po defaultu iz kutije nije radilo i ako je trebalo.
AroX
Asrock B650M-HDV/M.2
RTX 3080 FE 10GB
Benq zowie xl2566k
A2000 1TB
Logitech g pro x
Raijintek arcadia iii
Be quiet system power 9 600w
Jotel 150/50
Google Chrome
Pre nego sto pokusas menjanje kabla, mozes pokusati i da ugasis freesync i da vidis da li onda imas 144hz, nista te ne kosta :)
Freesync nema veze sa tim.
AroX
RTX 3080 FE 10GB
Benq zowie xl2566k
A2000 1TB
Logitech g pro x
Jotel 150/50
Google Chrome
Kod jednog modela monitora, 4k 144hz ne znam tacno imena, prijatelju nije radio 144hz mod preko hdmi kabla sve dok nije ugasio freesync. Vredi pokusati.
