Dukanyx
AMD Ryzen 7 3700X @ 4,4Ghz 1.4 V & NZXT Kraken X72
ASRock X470 Taichi
Corsair Dominator Platinum RGB 48GB - OC @ 3800Mhz
MSI GeForce RTX 2080 Ti Gaming X Trio
LG 27GL850-B UltraGear 27 Zoll WQHD Gaming Monitor (1 ms, G-SYNC, 144 Hz)
Samsung SSD 970 EVO Plus Series NVMe 1 TB V-NAND MLC - M.2, WD Elements™, 2 TB HDD, 2.5 Zoll, extern
Logitech Z607 5.1, Sonos One - Smart Speaker, 2x50W Klipsch
PHANTEKS Enthoo Evolv X Midi-Tower, RGB, Tempered Glass, 4 x Noctua NF-A14 PWM chromax
Seasonic FOCUS Plus Platinum 850W, MDPC-X Kabel-Sleeves
Corsair M65 RGB ELITE & Corsair K70 RGB MK.2 Low Profile Rapidfire Mechanical Gaming Keyboard
1&1-50/10mb
Windows 10& Google Chrome
Sony KD55XE7077
Imam problem sa stampacem, printa samo plavu i crnu boju, svi kertridzi su puni, uradio sam factory reset, udate takodje, ostalo mi je samo da ga rastavim i ocistim. Da ga ne bih rastavljao bez potrebe, svaki savet je dobrodosao, hvala.
1,6 MB Pregleda: 127
3,5 MB Pregleda: 114
